update OpenZWave version
sirray
Post by sirray »
I noticed on my Domoticz (3.5838) it is using OpenZwave 1.4 and that on the OpenZwave project page that 1.5 has been released some time ago. Can OpenZwave be updated seperately by downloading the OpenZwave installation binaries and installing them? Or will I break my Domoticz installation?
sijones
Domoticz version: Git
Re: update OpenZWave version
Post by sijones »
The OpenZWave is compiled in to the application, you can't update it separately.
Is there some reason you want 1.5?
sirray
Post by sirray »
Well I have a problem with my TKB TZ68 (see: viewtopic.php?f=24&t=12676 )and there is an update for that device in 1.5 and a lot more devices are updated according the release notes:
Version 1.5
- Pull Request #743 - Updated Fibaro Devices from Navstev0 (Justin)
- Pull Request #740 - Updated Fibaro FGMS-001 ID's from Technosf (Justin)
- Pull Request #750 - Fix FreeBSD 10.1 and 10.2 Builds from stromnet (Justin)
- Pull Request #751 - Fibaro FGD212 Australia Codes from daemondazz (Justin)
- Pull Request #752 - Devolo Home Control Radiator Thermostat from blitzkneisser (Justin)
- Pull Request #753 - Fix Aeotec Minimote Default Value from nayrnet (Justin)
- Pull Request #737 - Add Enerwave ZW15S, ZW20R, ZW500D from chadparry (Justin)
- Pull Request #759 - Qubino Supplied Config Files (Justin)
- Add Vision ZF5201 Flood Sensor ID's from Emmanuel Pierre (Justin)
- Issue #741 - Add new ID's for TZ68 Devices from philosifer (Justin)
- Pull Request #761 - Add support for Fakro ARZ from pepeEL (Justin)
- Pull Request #762 - Fix issues with Horstmann Thermostat from russdan (Justin)
- Pull Request #764 - Add Dlink DCH-Z510 Siren from pepeEL (Justin)
- Pull Request #766 - Add zwave.me ZME_05461 Dual load wall switch from koelie (Justin)
- Pull Request #767 - Correct update param. from manual for Fibaro FGS221 from pepeEL (Justin)
- Issue #757 - New ZMNHID1 config file stephaneguillard (Justin)
- Issue #754 - New Philio PAN08-1 config file from pbda (Justin)
- Pull Request #768 - Update Fibaro FGS222 from manual from pepeEL (Justin)
- Pull Request #768 - Small correct Fibaro FGS221 from manual from pepeEL (Justin)
- Pull Request #773 - Ecolink Door/Window Sensor from nayrnet (Justin)
- Pull Request #780 - Add D-Link dch-z120 PIR/motion sensor from mattwire (Justin)
- Pull Request #782 - If we recieve a UPDATE_STATE_NEW_ID_ASSIGNED and the Old and New NodeID's
are the same, don't reinitialize the Node from KillerCode (Justin)
- Issue #774 - Improve support for Aeotec Double Smart switch from dnpwwo (Justin)
- Issue #796 - Fix NotifyWatchers not releasing Value References from jmattoni (Justin)
- If UserCode returns a Available Status for a Slot, Don't set Random Values on the ValueID (Justin)
- Pull Request #779 - Large Config Update from Jeedom project (Justin)
- Add Additional tests on Config Files for common errors (Justin)
- Pull Request #810 - Add Enerwave ZWN-BPC configuration from robbiet480 (Justin)
- Pull Request #809 - Correct spelling: faillure -> failure from Mashi (Justin)
- Pull Request #805 - New device: Everspring AN181 Miniplug with meter function from FredrikFornstad (Justin)
- Pull Request #803 - Configs for Remotec ZTS-110 thermostat from gwmullin (Justin)
- Pull Request #797 - Leviton VRMX1-1LZ - additional hardware id from shanemadden (Justin)
- Pull Request #811 - Updated GE GE 12724 3-Way Dimmer Switch, missing config from Halsafar (Justin)
- Pull Request #869 - New device TZ88E and RaZBerry, missing config from travellingkiwi (Nechry)
- Pull Request #870 - New device Popp KFOB and PH-PSE02.eu Zipato Indoor Siren, missing config from RaymondNg2 (Nechry)
- Issue #807 - Update doco to reflect correct values returned from Notifications
- Pull Request #858 / Issue #847 - Fix for devices sending empty UserCodes from Binli71 (Justin)
- Issue #843 - Possible fix for setting Clock (Justin)
- Pull Request #864 - Add 2gig CT50e thermostat with USNAP RTZW-01 module from neudorf (Justin)
- Pull Request #855 - Update MinOZW: Print the names for nodes and values that have beed detected in the network from alan-martinovic (Justin)
- Pull Request #842 - add GR-105N from narfight (Justin)
- Pull Request #838 - Fixed crash on Windows systems. Timestamp (m_stamp)not parsed as pointer (Used in the Control Panel) from gizmocuz (Justin)
- Pull Request #802 - Debian Package Updates from julienw (Justin)
- Pull Request #800 - Device Support: Enerwave ZW20RM configuration params from shanemadden (Justin)
- Pull Request #799 - Device Support: GE 12724 Dimmer configuration params from shanemadden (Justin)
- Pull Request #798 - Device Support: Nexia DB100Z Z-Wave Doorbell Sensor configuration params from shanemadden (Justin)
- Pull Request #871 - Fix warning on wcsdup implicit declaration from ffontaine (Justin)
- Pull Request #874 - Device Support: Domitech Smart LED Light Bulb ZB22UK (Nechry)
- Pull Request #795 - Add Danfoss RoomSensor and Duwi Static Controller (Nechry)
- Pull Request #877 - Add support for FGK101 with type 0701 / id 1001 from gizmocuz (Nechry)
- Pull Request #876 - fixed Botton typo in DoorLockLogging CC from hcooper (Justin)
- Pull Request #873 - Fix libopenzwave.pc when using custom values from ffontaine (Justin)
- Pull Request #861 - Add support for building with BitBake Environment from binli71 (Justin)
- Pull Request #879 - Fixed setting Thermostat Clock from gizmocuz (Justin)
- Pull Request #888 - Added Fibaro FGMS001 2016 USA version from Clancey (Nechry)
- Issue #895 - There are now 2 danfoss room sensor definitions with type="0003" id="8010" (Nechry)
- Pull Request #901 - Jeedom Config Updates (Justin)
- Pull Request #899 - Ensure correct git repository path from ffontaine (Justin)
- Pull Request #904 - add vision zp3111 multisensor from N5QM (Nechry)
- Add Wall Dimmer Set for Busch-Jaeger DURO 2000 (Nechry)
- Issue #900 - update ZME_WCD2 config file from gomba777 (Justin)
- Issue #907 - Undocumented Vision ZD2102-5 Alarm Report response mark open contact as closed from NotTheEvilOne (Nechry)
- Add Qubino ZMNHZDx Weather Station Z-Wave+ (Nechry)
- Add Fibaro FGFS101 Zwave+ Flood Sensor (Nechry)
- Add Zipato PH-PSG01 Smoke Sensor (Nechry)
- Pull Request #909 - Add devices Leviton DZPD3-1LW and DZPA1-1LW from benweb (Nechry)
- Pull Request #910 - Add device Assa Abloy Yale Key Free Push Button Deadbolt from benweb (Nechry)
- Pull Request #913 - Add device Stelpro Electronic Thermostat STZW402+ from benweb (Nechry)
- Pull Request #911 - Added Ecolink door/window sensor and fixed Ecolink PIR Motion sensor from gdombiak (Nechry)
- Add Electronic Solutions Inc DBMZ Motor Control (Nechry)
- Add Remotec ZRC-90 (Nechry)
- Pull Request #914 - Update tz66d.xml from saintman23 (Nechry)
- Pull Request #915 - Update manufacturer_specific.xml saintman23 (Nechry)
- Pull Request #925 - Adds support for the AU/NZ frequency of the Fibaro Door and Window Sensor, FGK101. philhawthorne (Nechry)
- Issue #924 - Fix Mem Leak in SwitchMultiLevel from jmattioni (Justin)
- Pull Request #929 - Update manufacturer_specific.xml from saintman23 (Nechry)
- Pull Request #930 - Update manufacturer_specific.xml from saintman23 (Nechry)
- Pull Request #934 - Manufacturer ID for AU NZ update from Dilepa (Nechry)
- Issue #935 - Qubino zmnhvd1 / Zmnhvd* not supported from machielw (Nechry)
- Pull Request #936 - Set G.R. 105n working from narfight (Nechry)
- Issue #931 - Handle NONCE Report messages if we don't have a currentMsg (Justin)
- Add Aeotec ZW117 Range Extender 6 (Nechry)
- Pull Request #951 - Added GE 12727 In-Wall Smart Switch from vincemic (Nechry)
- Pull Request #941 - Add device Assa Abloy Yale Keyfree Connected Smart Lock from nickperry (Nechry)
- Issue #954 - Add Popp Radiator Thermostat to config from daniarv (Nechry)
- Add Aeotec ZW121 LED Strip (Nechry)
- Issue #947 - Add install_name to the library on OSX from irundaia (Justin)
- Add Aeotec ZW130 WallMote Quad (Nechry)
- Pull Request #959 - Add LB60Z-1 Dimmable LED Light Bulb from KyleARector (Nechry)
- Add NorthQ NQ-9021 Power Reader config file (Nechry)
- Add Z-Wave.Me ZME_064381 Wall Plug switch Schuko (IP44) - Gen 5 (Nechry)
- Add Z-Wave.Me Z-Uno (Nechry)
- Pull Request #969 - Neo Coolcam Power Plug from LouiS22 (Nechry)
- Add Fibaro FGPB101 Button (Nechry)
- Pull Request #970 - Neo CoolCam Door/Window Detector from LouiS22 (Nechry)
- Add Fibaro fgs213 and 223 from sarakha63 (Nechry)
- Pull Request #974 - Add support for AU/NZ Frequency Remotec ZXT120 IR Controller from philhawthorne (Nechry)
- Pull Request #972 - Neo CoolCam Battery Powered PIR Sensor from LouiS22 (Nechry)
- Add Wenzhou TKB Control System TZ55 and TZ56 from sarakha63 (Nechry)
- Add FortrezZ WWA-02 Water and Temperature Alarm (Nechry)
- Pull Request #978 - Added the BeNext P1 Dongle to the manufacturer_specific.xml file from gizmocuz (Nechry)
- Pull Request #981 - Added support for GE 12721 Lighting Control Duplex Receptacle from ThomasADavis (Nechry)
- Pull Request #980 - Update manufacturer_specific.xml from bailz (Nechry)
- Add GR GR105 Auto Valve config file (Nechry)
- Add NodOn MSP-3-1-XX Micro Smart Plug from sarakha63 (Nechry)
- Add Zipato PH-PAB01.eu Micromodule Energy Meter (Nechry)
- Add Zipato MH-P210 Mini Energy Dimmer, Mcohome branded (Nechry)
- Add WiDom WDS Universal Double Switch (Nechry)
- Add FortrezZ WV-01 Automated Water Shut-Off Valve (Nechry)
- Pull Request #992 - Devolo Metering Plug and Permundo Plugs from tobiasgraf (Nechry)
- Add configuration file for First Alert ZCombo Smoke and Carbon Monoxide Detector (Nechry)
- Issue #998 - Add Zooz ZEN07 Mini Plug from DeviantEng (Nechry)
- Issue #999 - Add new id in Fibaro fgd212.xml from DeviantEng (Nechry)
- Issue #1004 - Add support config for Neo Coolcam NAS-WS02Z water leakage sensor from nmaster2042 (Nechry)
- Add BeNext Panic Watch (Nechry)
- Pull Request #1006 Unknown: id=0176 Unknown: type=0005, id=0001 (Telldus TZDW-100 Magnet Switch) from ic3cool (Nechry)
- Pull Request #1007 Fibaro_FGK10x from tobiasgraf (Nechry)
- Pull Request #1008 Devolo devices from tobiasgraf (Nechry)
qwerk
Post by qwerk »
I also would like the 1.5 version.
I have the same problems with the TKB TZ68, after an update for domoticz/a restart I have to switch all my TKB switches to be recognized again.
marynofear
Post by marynofear »
Where do you find 1.5 :?:
I only find 1.4.2228 lastest from today and 1.4.164 stable. :roll:
So if you see something I dont, please send a link. :!:
ERROR: Keyboard not attached. Press F1 to continue............
No Fear Max Is Here
sirray
Post by sirray »
I have found it on github under releases: https://github.com/OpenZWave/open-zwave/releases
Derik
Post by Derik »
Think that gizmocuz have a reason for that.... :D
Perhaps ask him... :roll:
sirray
Post by sirray »
That is why I posted the question in the forum. I will try to contact him directly. :)
rwijngaa
Domoticz version: 3.5837
Post by rwijngaa »
I would too, like to use the 1.5 version because of a fix for the Danalock.
Keep us posted ?
Rino
sirray
Post by sirray »
I received an answer. The xml files are updated with newer openzwave versions, and these files are then included in Domoticz. I checked with my domoticz beta version and the xml files are the same as the most recent github repository :)
nizaga
Post by nizaga »
Hi! Just to be sure.. you mean xml files are uploaded to domoticz with beta releases even if the openzwave version is still 1.4? If you run a new domoticz installation from source, would it be then possible to update to the latest OZW versión? Thanks
Enviado desde mi iPad utilizando Tapatalk Pro
Kender
Post by Kender »
Hi!
Sirray if I downalod, untar and make https://github.com/OpenZWave/open-zwave ... 1.5.tar.gz ... at the end I have a 1.4 version did I do something wrong ? do I have to set some variable/prefix or something different ?
Thank you very much !
Kender
jannl
Domoticz version: 2026.1.x
Post by jannl »
If you want to use an update openzwave with a precompiled Domoticz, that is not going to work. In order to do that you also need to recompile Domoticz with the new openzwave libraries. Openzwave is compiled in.
Kender
Post by Kender »
This is what i did:
- download openzwave 1.5 tar (or download last Openzwave from git)
- untar it in the folrder open-zwave-read-only
- make it
- during the execution of make command i can see that it's making the 1.4 version :( :(
- download from git domoticz
- make it
went to the web gui and what I can see is Domoticz 3.6591 and openzwave 1.4-2384 :( :( :(
Do I have to put some parameter during the make of the Openzwave ?
Thank you.
kender
jannl
Post by jannl »
You followed the instruction for zwave on the wiki?
https://www.domoticz.com/wiki/Installin ... _OpenZWave
Kender
Post by Kender »
Yes,
I followed all the part "Installing from Source"
Update:
After the cloning of the git repository you have to enter in the folder and change the git branch with the comand: git checkout Dev
At this point, if you make openzwave you'll have the 1.5 version.
Now the problem is that I have an error compiling the file Driver.o :evil: :evil: :evil: :evil: :evil:
mauricedudeley
Post by mauricedudeley »
I don't think you can just update the openzwave installed. I think you have to clean it off and recompile or if you're not satisfy try
some other resources online .
http://www.consumeressentials.com/best- ... hermostat/
constapel
Post by constapel »
Does somebody know if there are plans (agenda) to integrate the 1.5 OpenZWave (ozw) version into domoticz?
https://github.com/OpenZWave/open-zwave ... s/tag/V1.5
dutchdevil83
Domoticz version: latest
Post by dutchdevil83 »
constapel wrote:Does somebody know if there are plans (agenda) to integrate the 1.5 OpenZWave (ozw) version into domoticz?
+1 on that, also want to know when this version is integrating with domoticz
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
1x GoodWe Solarpanels
2x FGSD-002 Smoke Detector
1x FGBS-001 Binaire Sensor (RFID lezer)
7x FGMS-001 Motion Sensor
3x ZW089 Verzonken Deursensor
7x NC Wallplug
&lots of KaKu stuff
marin849
Domoticz version: 2.4xxx
Post by marin849 »
What does it mean that Openzwave is "compiled in"?
Has the Openzwave source code been checked out at some point in time and included in the Domoticz source?
And the configuration files are regularly updated from Openzwave and updated in Domoticz source also?
