DI-O dimmer
nigels0
Domoticz version: 3.8153
DI-O dimmer
Post by nigels0 »
Hi, I have one of these, but I suspect I'm going to have a problem installing it in a room where three light switches control the same light. Does anyone have any good suggestions as to whether it is possible or not - and if so, how could I wire it.
The D-IO from Chacon is basically a module that fits behind the light switch and has two wires that normally go to the existing switch, and the wires coming into the switch previously go into the dimmer.
Thanks in advance
