Domoticz Remote Access
Posted: Friday 28 October 2016 1:41
by sghazagh
I am new to Domoticz and have some issue with remote access to the server.
That's not about network configuration.My router is forwarding properly to the server inside my LAN and port has been configured correctly.
I also can see the login page and can login to Domoticz as well.
My issue is that, when I login remotely, none of the settings shows and it looks like you have started from the scratch.
When I connect through LAN or VPN to my LAN, all the settings , devices and... are there.
Why I cannot see my stuff when I login from outside my LAN?
Re: Domoticz Remote Access
Posted: Tuesday 01 November 2016 21:03
by sghazagh
Nobody have this issue? at least tell me if it's only my problem!
I still cannot get it loaded properly from outside of my LAN!
Posted: Tuesday 01 November 2016 21:08
by Skippiemanz
Already cleared the cache and refreshed your page?
Or try a different browser for testing.
Posted: Tuesday 01 November 2016 21:11
by sghazagh
Yes mate, I tried both.
When I login remotely, I only can see the Setup button. and it has nothing. Like you started from the scratch!!!
Posted: Tuesday 01 November 2016 21:14
by jvdz
have you checked the access rights for the username you use to access remotely?
Jos
Posted: Tuesday 01 November 2016 21:16
by sghazagh
Where is it?
I am using my main username...
I am double checking now....give me a minute...
Posted: Tuesday 01 November 2016 21:22
by sghazagh
I only see my main login under "Website Protection" which I normally use to login to dashboard.Authentication is set to "login Page".
In front of that, there is "Security Panel" which I use the same password , delay is set to 30 seconds.
Bellow is "Remote Share Port" which I have set to the port I am accessing from outside!
Posted: Tuesday 01 November 2016 21:30
by sghazagh
Oh God,
I don't know what was wrong but I have created another user and changed the Login from "Login Page" to "Basic-authenticate" and it's now working!!!
Posted: Tuesday 01 November 2016 21:35
by sghazagh
Guys,
I can confirm that the issue is for login method.
The "Basic-Auth" works fine but "Login Page" doesn't!
Posted: Sunday 05 March 2017 13:12
by OldPensionado
sghazagh wrote:Guys,
I encountered more or less the same problem: in my situation I couldn't login at all. After entering username and password (these were correct, no messages about wrong username/password combination) I see the login screen again, and again. (Although it is weird that the proposed username is "Admin" and a four characters password.)
Lucky enough I had made a backup of the SD-card (using USB Backup) so I restored the backup, booted the RPi up and I got into the Webgui without any password.
Then I entered again a username/password at "Website Protection" but now with Basic-Auth. And this works indeed fine!
Lessons learned: to backup or not to backup, that's the question...
Posted: Tuesday 11 September 2018 6:58
by amplituda
sghazagh wrote: Tuesday 01 November 2016 21:35
Guys,
Thank you very much, it works and now it's good!)
