Simple "Toggle" Switch LUA
Posted: Thursday 27 October 2016 14:43
by DomoSeb
I am trying to figure out why my LUA script is not fired/not works.
I have tried a couple of alternative ways, but I seem to be able to figure out why it is not fired!
Can you guys give me a suggestion?
(I am well aware that this has to be plain simple, but I have no clue at the moment where to dig deeper to make it work)
Here is my code:
if (devicechanged['Switch - Shed Inside']) then
if (commandArray['Relay - 03 - Lamp Shed Inside']=='On') then
commandArray['Relay - 03 - Lamp Shed Inside']='Off'
elseif (commandArray['Relay - 03 - Lamp Shed Inside']=='Off') then
commandArray['Relay - 03 - Lamp Shed Inside']='On'
--elseif (otherdevices['Switch - Shed Inside'] == 'Closed') then
-- if (commandArray['Relay - 03 - Lamp Shed Inside']=='On') then
-- commandArray['Relay - 03 - Lamp Shed Inside']='Off'
-- elseif (commandArray['Relay - 03 - Lamp Shed Inside']=='Off') then
-- commandArray['Relay - 03 - Lamp Shed Inside']='On'
-- end
'Switch - Shed Inside' = contact switch based on GPIO input
'Relay - 03 - Lamp Shed Inside' = on/of switch controlling GPIO output -> relay
Re: Simple "Toggle" Switch LUA
Posted: Thursday 27 October 2016 14:52
by Sneezydevil
Replace the commandArrays within the if's with something like:
otherdevices['Relay - 03 - Lamp Shed Inside']
Now you first create a empty array (commandArray = {}), and is still empty when you start checking.
Should result in something like this.
if (otherdevices['Relay - 03 - Lamp Shed Inside']=='On') then
elseif (otherdevices['Relay - 03 - Lamp Shed Inside']=='Off') then
Posted: Thursday 27 October 2016 15:37
by DomoSeb
TY very much, working now.
Posted: Monday 23 December 2019 18:00
by Roozen
I am trying to integrate the simple toggle function as action for a fibaro dimmer2 S2 singleclick.
Sounds simple, but somehow I can not get it work.
This is the script I am using:
if (devicechanged['$S2 SingleClick']=='On') and (otherdevices['Tuinverlichting']=='Off') then
commandArray['Tuinverlichting']='On'
elseif (devicechanged['$S2 SingleClick']=='On') and (otherdevices['Tuinverlichting']=='On') then
commandArray['Tuinverlichting']='Off'
Any idea what I am doing wrong?
Posted: Monday 13 January 2020 14:15
by bewo
Hi Roozen,
your script looks quite ok. Are you sure the name contains an "$"?
If yes, you can try an other way:
if devicechanged['$S2 SingleClick'] then
if otherdevices['Tuinverlichting'] == 'Off' then
commandArray['Tuinverlichting'] = 'On'
commandArray['Tuinverlichting'] = 'Off'
If this didn't work, there sometimes is an issue with the dimmer state, so there you can use:
if otherdevices['Tuinverlichting'] == 0 then
commandArray['Tuinverlichting'] = 'Set Level 100'
commandArray['Tuinverlichting'] = 'Set Level 0'
Posted: Wednesday 15 January 2020 19:12
by Roozen
Hi Bewo,
Thanks for your reply.
The above script works partially if the "tuinverlichting" is on
Then the "Tuinverlichting will switch off when pressing the $S2 Singleclick button
When pressing again it will not toggle on again
Looks like the part after else is not working
When I reverse the on/off as below, nothing happens
if otherdevices['Tuinverlichting'] == 'On' then
The log states "Status: EventSystem: Script event triggered: Script #1"
No error visible
No Idea what to change.
I am using a fibaro dimmer switch ($S2 SingleClick) and try to trigger a neo coolcam wall plug (Tuinverlichting)
Posted: Thursday 16 January 2020 2:02
by bewo
Ok... When it's off.... what ist the log output of:
print('State: '..otherdevices['Tuinverlichting'])
print('Value: '..otherdevices_svalues['Tuinverlichting'])
Posted: Thursday 16 January 2020 17:08
by Roozen
When off:
2020-01-16 17:05:19.607 Status: LUA: State: Off
2020-01-16 17:05:19.608 Status: LUA: Value: 0
When on:
2020-01-16 17:06:25.599 Status: LUA: State: On
2020-01-16 17:06:25.600 Status: LUA: Value: 100
Posted: Thursday 16 January 2020 17:33
by Roozen
I have updated to script as below to monitor whether the else if commend is working corrrectly. This is the case
if devicechanged['$S2_SingleClick'] then
if otherdevices['Tuinverlichting']=='Off' then
commandArray['Tuinverlichting']='100'and
print('Tuinverlichting aan')
commandArray['Tuinverlichting']='0' and
print('Tuinverlichting uit')
If tuinverlichting is off, then it prints
2020-01-16 17:24:42.968 Status: LUA: Tuinverlichting aan
If tuinverlichting is on, then it prints
2020-01-16 17:23:00.116 Status: LUA: Tuinverlichting uit
Also changed the commandArray to 0 and 100 in stead of Off and On
This has no effect
When using the "tuinverlichting' switch everything works fine wth switching.
Log:
2020-01-16 17:34:20.758 Status: User: administrator initiated a switch command (10/Tuinverlichting/Off)
or
2020-01-16 17:34:20.758 Status: User: administrator initiated a switch command (10/Tuinverlichting/On)
It looks like something in the commandArray is not functioning
Posted: Thursday 16 January 2020 18:59
by bewo
Ok, the log output is as expected..
Your command can't work because of a kind of grammar in LUA und case sensitivity. In this case it's not possible to write only 0. It have to be 'Set Level 0'.
I misunderstood and i thought "Tuinverlichting" ist the lamp which should be dimmed but it's the wall plug. So my scripts above CAN'T work. Sorry about that.
There are some issues with the state of the fibaro dimmer as trigger in devicechanged table, but it's possible.
Just copy & paste this and have fun. I guess it will work.
-- Turn wall plug off:
if devicechanged['$S2 SingleClick'] == 'Off' then
-- Turn wall plug on:
if string.sub(otherdevices['$S2 SingleClick'], 1, 10) == 'Set Level:' or otherdevices['$S2 SingleClick'] == 'On' then
