Setting up RFLink - Please help!
Froobage
Post by Froobage »
Hello all,
I'm hoping someone could possibly help me out, I'm a complete novice.
Hardware
I'm using an arduino mega 2560 (Bus 001 Device 004: ID 2341:0042 Arduino SA Mega 2560 R3 (CDC ACM)) and some cheap Chinese Rx Tx 433mhz FS10000A.
Connections:
Reciever - Arduino
Data > RX1 (Digital 19)
GND > GND
VCC > TX2 (Digital 16)
Transmitter - Arduino (Transmitter pins are 4321 looking top down)
Pin 1 (GND) > GND
Pin 2 () > RX3 (Digital 15)
Pin 3 () > TX3 (Digital 14)
Pin 4 (ANT?) > Not connected
Firmware is RLink Firmware Version: 1.1 Revision: 43
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R43;
10;version;
20;01;VER=1.1;REV=43;BUILD=0a;
10;rfdebug=on;
20;02;RFDEBUG=ON;
Domoticz is up to date running on raspberry pi 2
initially it was showing up as ttyACM0 but I set it as a persistent device, I've added it as hardware:
6 Gateway Yes RFLink Gateway USB
but there is no button next to it saying setup devices, I've tried clearing the cache, checked for latest updates but still no progression. Have I done something wrong here like put the connections on the hardware incorrectly?
Any support greatly appreciated.
Thanks,
Froob
Stuntteam
Re: Setting up RFLink - Please help!
Post by Stuntteam »
Try a different browser..
also note that the FS1000A is not a very good receiver module.
It is fine for an initial test drive but you should replace it for something better like a RXB6, Syn or Aurel.
Froobage
Post by Froobage »
Hi Stuntteam,
I've tried both internet explorer and chrome but neither of them are showing the button.
deennoo
Post by deennoo »
Which domoticz version did you use ?
http://domo-attitude.fr
Froobage
Post by Froobage »
Hi Deennoo,
its Version: 3.4834
Build Hash: 8398125
Compile Date: 2016-03-02 07:43:51
deennoo
Post by deennoo »
Ok probleme is here, please upgrade to last beta to use this fonction.
Froobage
Post by Froobage »
Thanks deennoo, I've upgraded to the beta and I now see the add manual devices, but now I've encountered another issue, when I press learn devices, it doesn't pick anything up i.e. Home Easy light switch/wall plug sockets/motion sensor. Is there a command that can be done on rflink loader tool to prove the transmitter and receiver have been terminated to the correct pins on the arduino?
deennoo
Post by deennoo »
Your rx parts is crap, you must/need to change it first for one of the mentionned by Stuntteam
Stuntteam
Post by Stuntteam »
You should not use "learn devices"
Most devices are picked up automatically and placed in your device list.
unless you have disabled that under settings.
Froobage
Post by Froobage »
Hi All,
Thanks for the replies, i've purchased the RFlink 433 kit from Nodo and set it up today, but i'm having issues connecting my devices.. I have a few HE107's and HE109's and HE851's from the Home easy range, as well as some Silvercrest on/off sockets but the only thing the gateway seems to pickup is the HE851 PIR. Am I doing something wrong in order to pair the other devices?
Thanks,
Froob
Froobage
Post by Froobage »
Also HE304 units have the same issue too.
Stuntteam
Post by Stuntteam »
I have send you a PM regarding support..
