HowTo: monitor Synology NAS
Posted: Sunday 12 January 2014 14:05
Now in the WIKI: http://www.domoticz.com/wiki/NAS_Monitoring
In addition to the post of mbliek about setting up monitoring for a QNAP NAS, here is the how to for a Synology NAS.
I have used most of the info from his topic (http://www.domoticz.com/forum/viewtopic.php?f=17&t=1337), so the credits are for him
Below you'll find the how-to:
First enable SNMP on your Synology NAS:
You can find the option in the Configuration Screen, it's a sub-option in "Network Services".
You can use V1/V2
And set a password (Community)
Then install SNMP on your RaspberryPi
sudo apt-get install snmpd
Reboot Pi
Check if SNMP is up and running:
The result will be an Integer giving you the temperature in Degrees Celcius, in my case it was:
"40"
Every device (I.E. Qnap or Synology has it own implementation layer regarding commands for SNMP, you can use the documentation together with the command line tool snmpwalk to get more information on which codes to use to get a specific output for temperature of used disk space. Below you'll find an example using snmpwalk to get more information:
Make 3 new virtual Temperature Sensors (NAS HD1, NAS HD2 and NAS Free HD)
And 1 new virtual Switch (NAS)
nas.sh (in domoticz/scripts/)
Change the idx to your own idx
Make this script executable:
sudo chmod +x nas.sh
Try the script out:
./nas.sh
You should get something like:
Make a new crontab job:
crontab -e
*/5 * * * * /home/pi/domoticz/scripts/nas.sh (= every 5 minutes)
Forgot to say
I did made a room called NAS and put all my virtual sensors and switch there.
Thats it, any question? Just ask.
As mbliek mentioned in his topic:
07-02-14 change Changed a hardcoded number into a variable, thanks to BigDog for noticing
You can use V1/V2
Reboot Pi
snmpget -c PASSWORD -v2c -O qv NASIPADDRESS .1.3.6.1.4.1.6574.1.2.0"40"
snmpwalk -c PASSWORD -v2c -O qv NASIPADDRESS .1.3.6.1.4.1.6574.1.2
Ouput will be someting like:
iso.3.6.1.4.1.6574.1.2.0 = INTEGER: 40
as you can see, you need to use the additional ".0" at the end to get the temperature of your Synology NAS.
#!/bin/bash
# Settings
NASIP="0.0.0.0" # NAS IP Address
PASSWORD="password" # SNMP Password
DOMO_IP="0.0.0.0" # Domoticz IP Address
DOMO_PORT="0000" # Domoticz Port
NAS_IDX="16" # NAS Switch IDX
NAS_HD1_TEMP_IDX="14" # NAS HD1 Temp IDX
NAS_HD2_TEMP_IDX="13" # NAS HD2 Temp IDX
NAS_HD_SPACE_IDX="15" # NAS HD1 Temp IDX
# Check if NAS in online
PINGTIME=`ping -c 1 -q $NASIP | awk -F"/" '{print $5}' | xargs`
echo $PINGTIME
if expr "$PINGTIME" '>' 0
then
echo "NAS ON"
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=switchlight&idx=$NAS_IDX&switchcmd=On"
# Temperature HD1
HDtemp1=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.6574.2.1.1.6.0`
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_HD1_TEMP_IDX&nvalue=0&svalue=$HDtemp1"
# Temperature HD2
HDtemp2=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.6574.2.1.1.6.1`
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_HD2_TEMP_IDX&nvalue=0&svalue=$HDtemp2"
# Free space volume
HDUnit=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.2.1.25.2.3.1.4.36`
HDTotal=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.2.1.25.2.3.1.5.36`
HDUsed=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.2.1.25.2.3.1.6.36`
HDFree=$((($HDTotal - $HDUsed) * $HDUnit / 1024 / 1024 / 1024))
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_HD_SPACE_IDX&nvalue=0&svalue=$HDFree"
echo "NAS OFF"
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=switchlight&idx=$NAS_IDX&switchcmd=Off"
fi
Try the script out:
./nas.sh
1
NAS ON
HTTP/1.0 200 OK
Content-Length: 51
Content-Type: text/html;charset=UTF-8
Cache-Control: no-cache
Pragma: no-cache
"status" : "OK",
"title" : "SwitchLight"
HTTP/1.0 200 OK
Content-Length: 53
Pragma: no-cache
"status" : "OK",
"title" : "Update Device"
HTTP/1.0 200 OK
Content-Length: 53
Pragma: no-cache
"status" : "OK",
HTTP/1.0 200 OK
Content-Length: 53
Pragma: no-cache
"status" : "OK",
crontab -e
Forgot to say
This is it for now, if you have any questions let me know. And again the credits go out to the original poster mbliek with his topic:Forgot to say
