problems with fibaro Motion Sensor FGSM001 ZW5
jorgitold
Domoticz version: 3.5839
Post by jorgitold »
problems with fibaro Motion Sensor FGSM001 ZW5 with firmware 3.02 because it doesn't send a message when motion is detected.
someone has idea?.
I read that in antiguias versions of this sensor problems existed:
"The Fibaro Motion Sensor with firmware 2.4 is not recommend, because it doesn't send a message when motion is detected. Version firmware 2.6 have been successfully tested."
I have the latest version of domoticz installed in raspberry pi 3. The rest temperature and light sensors are working properly
regards
jorgitold
Re: problems with fibaro Motion Sensor FGSM001 ZW5
Post by jorgitold »
The new sensors use Z-wave Plus and secure encapsulation, which means we need to handle the events and commands a little bit differently. It's essentially a brand new device, not just an update to an existing device.
dospider
Post by dospider »
Can explain a little bit more?
I have the The version with 3.02. Added it to the xml file and only see this in domoticz
FIBARO System Unknown: type=0801, id=1001
It isn't working at all. Installed the beta version of domoticz but it didn't help.
I have the OpenZWave USB Version: 1.4-340-g71af464-dirty . Must this be updated? If so how?
