Split values from netatmo weather station
joda
Post by joda »
Hello, I am novice with Domoticz but for the moment I managed to add my air conditionings Daikin as well as my netatmo weatherstation.
I have a problem with Netatmo, the values from the outside module are combined in a single device, in Domoticz I see temp/humidity for the external device and temp / humidity / noise for the indoor device like this post :viewtopic.php?f=12&t=3830
There a way to split the values to have each of them in a single device like:
ID1: outdoor temperature
ID2: outdoor humidity
ID3: outdoor battery level
ID4: indoor temperature
ID5: indoor humidity
ID6: indoor noise level
Etc..? :?
gizmocuz
Re: Split values from netatmo weather station
Post by gizmocuz »
Whats the problem with that ? It is a Temp+Hum device after all
If you want to do some scripting, you should be able to take them apart
joda
Post by joda »
For me it's a problem because I want to use each values in a independant way and especially that the values display correctly on the home application on iOS with the homebridge-edomoticz plugin
joda
Post by joda »
Ok I've used this script here :viewtopic.php?t=1817&start=20
It works great, thx
