Clean the Database?
Posted: Saturday 15 October 2016 19:14
by BarryT
please implend a "reset" button to clean all values/history of the database, without deleting the devices/hardware.
I just want to start over, for example the power usage and the gas, but it is not possible to just "reset" the database values without a sql manager..
We going moved over to another home in December, and as so far i get new (slim) meters, i just want to start over with the power usage, gas, to get a better monitor of the usage etc..
Would be great!
Re: Clean the Database?
Posted: Saturday 15 October 2016 22:29
by Egregius
Just use a sql manager. How many times will you need that?
If often, create some php page that deletes entrys from database, not that hard.
This script removes values from some tables for devices that aren't used or are older than one day:
<?php
$db = new SQLite3('/volume1/@appstore/domoticz/var/domoticz.db');
$clean = strftime("%G-%m-%d %k:%M:%S",time()-86400);
$tables = array('LightingLog','Meter','Meter_Calendar','MultiMeter','MultiMeter_Calendar','Percentage','Percentage_Calendar','Rain','Rain_Calendar','Temperature','Temperature_Calendar','UV','UV_Calendar','Wind','Wind_Calendar');
foreach($tables as $table) {
$query=$db->exec("DELETE FROM $table WHERE DeviceRowID not in (select ID from DeviceStatus where Used = 1)");
if ($query) {
$rows = $db->changes();
if($rows>0) echo $rows." rows removed from $table<br/>";
$query=$db->exec("DELETE FROM $table WHERE Date < '$clean'");
if ($query) {
$rows=$db->changes();
$sql = 'VACUUM;';
if(!$result = $db->exec($sql)){ die('There was an error running the query [' . $db->error . ']');}
Gives output like this:
2940 rows removed from Meter
4165 rows removed from Temperature
Posted: Wednesday 19 October 2016 18:23
by BarryT
Egregius wrote:Just use a sql manager. How many times will you need that?
<?php
if ($query) {
if ($query) {
$sql = 'VACUUM;';
Hmm, i installed nginx with sqlite3...
I'm getting, Fatal error: Class 'SQLite3' not found in /var/www/html/clean.php on line 2
Posted: Tuesday 01 December 2020 1:41
by ben53252642
BarryT wrote: Wednesday 19 October 2016 18:23
I solved that error on my system with: apt-get install php-sqlite3
Egregius thanks for the script!
