How to create a scheduled job in lua?
Posted: Monday 10 October 2016 13:34
Domoticz v3.57. Linux ARM. Debian wheezy.
I want to change the mode setting on a pair of thermostats at specific times in the day.
I've looked but cannot see any examples of how to make a setting at a specific time. I am using the in-built editor and saving as a time script. Both the following methods for retrieving the current time have failed for me.
and
I am debugging by printing to the log and can see that in the first instance that time is nil since the comparison to a number I have done produced "attempt to compare number with nil".
If I use the latter code (as in the full listing below) I see the error
"Error: EventSystem: in BedroomsEnergySave_time: [string "..."]:17: attempt to index global 'timenow' (a number value)"
Full code is as follows.
time = os.date("*t")
time = os.time()
print ("Time based event fired")
timenow = os.time()
print (timenow.hours)
print (" hours")
print (timenow.minutes)
print (" minutes")
if (timenow.hours>9) then
print ("It is after 0900 GMT")
for deviceName,deviceValue in pairs(otherdevices) do
if (timenow.hour == 19 and timenow.minutes == 1) then
if (deviceName=='T stat mode') then
if deviceValue == 'Comfort' then
print("T stat mode is Comfort")
commandArray['T stat mode'] = 'Energy Saving'
print("T stat mode switched to Energy Saving")
elseif (deviceName=='L stat mode') then
print("L stat mode is Comfort")
commandArray['L stat mode'] = 'Energy Saving'
print("L stat mode switched to Energy Saving")
elseif (timenow.hour == 8 and timenow.minutes == 35) then
if deviceValue == 'Energy Saving' then
print("T stat mode is Energy Saving")
commandArray['T stat mode'] = 'Comfort'
print("T stat mode switched to Comfort")
print("L stat mode is Energy Saving")
commandArray['L stat mode'] = 'Comfort'
print("L stat mode switched to Comfort")
