Using TR-064 in LUA Script for getting Fritzbox data
GiantBrain
Domoticz version: 3.8153
Post by GiantBrain »
i am pretty new in Domoticz and LUA therefore i hope my question is not to much stupid :P .
I read at the Fibaro Forum that they found a solution to get data from an fritzbox over the TR-064 protokoll.
Infos found here....
https://forum.fibaro.com/index.php?/top ... gh/&page=2
And someone posts a lua script that should wortk for Fibaro here...
https://www.siio.de/board/thema/tr-064- ... nsprechen/
I want to use WLAN status from fritzbox in Domoticz.
Is it possible to use this for Domoticz!?
Domoticz V3.4834 @ DS213+ DSM6
GiantBrain
Re: Using TR-064 in LUA Script for getting Fritzbox data
No Pro User who know if this is possible?
I can't believe no one is interested in router Infos from Fritzbox?!
I would try it by my own but i am not professional enough :-(
robhuls
Post by robhuls »
I played a bit with the Fritzbox interfaces last year but did not finish anything. I changed the approach to parsing the emails sent by the fritzbox to extract the data usage, but I did not even start implementing that. However, if the data you require can be extracted from the fritzbox using lua than it should be a simple hack to insert it into domoticz. Judging by the 550 line script you linked, talking to the fritzbox does not seem so trivial ... What do you mean with the WLAN status, track if a certain device is online? This can be done already using the scripts from chopperrob https://www.domoticz.com/wiki/Presence_detection that work with any router.
