add Somfy screen to Domoticz: UP/DOWN vs ON/OFF
Posted: Thursday 06 October 2016 21:08
by DomoFlits
I have attached the RFlink (version R43) to the PC and with RFLinkloader I have added my Somfy sunscreens to RFlink, according to the description of Supermat on https://matdomotique.wordpress.com/2016 ... -et-somfy/
when using RFloader with RFlink connected to the PC and send:
10;RTS;0F0F0F;0;DOWN;
or
10;RTS;0F0F0F;0;STOP;
or
10;RTS;0F0F0F;0;UP;
it works fine
Then I connect the RFlink to the Raspberry.
In Domoticz I have added a switch as "Venetian Blinds EU" (as indicated in above description), but it doesn't work.
In the log of domotics I see the following when I push
the "close" symbol:
RFLink Sending: 10;RTS;0F0F0F;1;ON
the "stop" symbol:
RFLink Sending: 10;RTS;0F0F0F;1;STOP
the "open" symbol:
RFLink Sending: 10;RTS;0F0F0F;1;OFF
probably because of it is sending ON of OFF instead of UP or DOWN it doesn't work?
any advice on how to proceed is welcome.
Re: add Somfy screen to Domoticz: UP/DOWN vs ON/OFF
Posted: Thursday 06 October 2016 21:46
by DomoFlits
I've connected the RFlink back to the PC and with RFLoader I checked and found out that
10;RTS;0F0F0F;0;ON;
and
10;RTS;0F0F0F;0;OFF;
also works, so probably there is something else.
Any good advice?
Posted: Friday 07 October 2016 8:39
by Stuntteam
10;RTS;0F0F0F;0;ON;
Clearly not the same command. Looks like your setup in Domoticz is incorrect.. and thus it does not work
Posted: Friday 07 October 2016 18:14
by DomoFlits
Thank you Stuntteam for your reaction.
I have tried in RFLinkLoader (while connected connected to the PC) the following commands:
10;RTS;0F0F0F;1;DOWN;
10;RTS;0F0F0F;1;ON;
both resulting in the screen going down
10;RTS;0F0F0F;1;UP;
10;RTS;0F0F0F;1;OFF;
both resulting in the screen going up
10;RTS;0F0F0F;1;STOP;
resulting it to stop.
That matches with the French tutorial that the "Unit Code" is not important.
putting the RFLink back to the raspberry (And then a reboot the raspberry from within Domoticz)
magically it works! (maybe the reboot did the job?)
anyway it works and thus problem solved!
