RTL_433 with watchman oil tank
Posted: Wednesday 05 October 2016 16:10
Just install a TV adapter and got my adapter setup and started the below in a ssh session:-
/home/pi/rtl_433# rtl_433 -R 42
It then states teh following:- (all good)
Registering protocol [1] "Watchman Sonic / Apollo Ultrasonic / Beckett Rocket oil tank monitor"
Registered 1 out of 68 device decoding protcols
Found 1 device(s):
0: Realtek, RTL2838UHIDIR, SN: 00000001
Using device 0: Generic RTL2832U OEM
Found Rafael Micro R820T tuner
Exact sample rate is: 250000.000414 Hz
[R82XX] PLL not locked!
Sample rate set to 250000.
Bit detection level set to 0 (Auto).
Tuner gain set to Auto.
Reading samples in async mode...
Tuned to 433920000 Hz.
My question's.
1. if i now close this ssh window (putty on my windows PC), i presume this will then stop the adapter monitor the frequency and stop logging the data?
2. My next step is get Domoticz to grab that data from rtl-$33, how do i achieve that? I presume the link below is the correct way of doing that, assuming the answer to question is not yes.
http://www.domoticz.com/wiki/Lua_-_Oil_ ... ticz_Setup
Cheers
Found 1 device(s):
My question's.
Cheers
