New meter
Posted: Thursday 29 September 2016 6:17
by alttab
I am moving to a new home with a new smartmeter.
Simple question: what will happen when you connect the new smart power meter to domoticz (p1)? It will start at 0 again. Basically going into the negatives
Will domoticz continue to register the power usage without screwing up the monthly / yearly usage stats?
Re: New meter
Posted: Thursday 29 September 2016 8:38
by piotr
No, you will see the actual, current, readings.
Re: New meter
Posted: Thursday 29 September 2016 18:53
by alttab
piotr wrote:No, you will see the actual, current, readings.
Thanks, what will happen to the yearly power usage? My old meter is on (for instance) 70000 kwh, new one is on 0 , will it be negative?
Re: New meter
Posted: Thursday 29 September 2016 19:53
by Derik
nope
This meter is a perfect [ fucking ] thing...
You get 4 counters.
2 up and 2 download
Every second you use counter x is counting
every second you deliver counter y is counting.
weekend/night and day..
with this 4 counters you must hope the [ salderingsregeling] is still alive for years..[ spring 2017 the gouvernement is voting ]
Other wise your solarpanelparty is over
And your deliver Kwh price is going down to 3-4 cents / KWh [ i think ]
And your use Kwh price is going up...
