Smartwares Valve Issue
Posted: Tuesday 27 September 2016 19:25
I'm new to Domoticz. My setup is Domoticz V3.5700 on Raspberry and RFLink from nodo-shop with V42 FW.
I can't add my Smartwares Valve in Domoticz, if I try to use the remote to learn the code it's only detected as an ON/OFF Switch and if I try to add it manualy (Switch Type : ON/OFF - TYPE : Smartwares Radiator) there is a missing 0 in the first row of the ID (should be 0069FC00 unit 2)
If I insist to create this Switch with the missing 0 in the ID, the Switch and Utility are created in Domoticz but if I try to use it anyway I'm getting an "Error sending switch command, check device/hardware !"
Any help will be appreciated
