Zwave devices and Device list (many devices)
dalhoj
Post by dalhoj »
Hi I'm new to Domoticz.
I have used Vera for some time, but would like to try something new.
I have a Aeon Labs USB Adapter with Battery GEN5 AEOEZW090-C installed as OpenZwave USB and it works fine.
I have included some devices, and it worked great.
My problem is
I added two Fibaro Dimmer modules, and under OpenZwave I named them each, but in the device list the show op as 11 devices, and the name is not there, the are just called Unknown, Level, Heat, Alarm and so on.
Are the a way to get the name I called it under OpenZwave to show up in the device list, and maybe not show the Dimmer as One device with sub devices, not 11 different devices?
Or what do you guys do?
Regrads
LouiS22
Re: Zwave devices and Device list (many devices)
Post by LouiS22 »
Hi, that's normal, you have to name them.
dalhoj
Post by dalhoj »
hmm ok, it seems like double the work to name all the devices two times.
So you only add one device and then rename, and the another or how do you work in Domoticz
Do you know if there is a way do see what zwave device a device in the device list is linked to, I can't see where the zwave id is in the device list ?
Evelen
Domoticz version: 2.4538
Post by Evelen »
Yes, look at this:
viewtopic.php?f=24&t=12881
