previous z-wave node still appears in Domoticz devices
Posted: Sunday 18 September 2016 22:52
by booster
I had a zwave device (greenwave powernode) which I had disconnected from any power for a few months.
Today I switched it on, but it wasn't synching anymore, therefore I re-added it on my z-wave network. This all works fine, but it got a completely new node ID.
The old devices are however still showing up in Domoticz...That's a bit surprising as I was assuming that removed nodes on my zwave network would automatically be removed from Domoticz?
Shouldn't those be deleted automatically? Or should I just delete them manually from the devices tab?
On the stick:
(node 12 - 0x0c is gone)
In Domoticz, the devices are still there:
Re: previous z-wave node still appears in Domoticz devices
Posted: Monday 19 September 2016 13:17
by cogliostrio
Domoticz will only add new devices from nodes. If you remove a node, you will have to keep track of the old devices yourself, and delete them.
Posted: Monday 19 September 2016 18:02
by booster
cogliostrio wrote:Domoticz will only add new devices from nodes. If you remove a node, you will have to keep track of the old devices yourself, and delete them.
Ah..didn't know that.. many thanks for confirming this, I'll delete them manually!
