ESP8266 gateway to Domoticz
insippo
I connect nrf24l01+ to esp8266 and install mysensors gateway software. Serial monitor looks ok. Small question. How to i configure domoticz to use this gateway ? In setup->hardware ?
- gizmocuz
Re: ESP8266 gateway to Domoticz
Add the MySensors serial gateway to the hardware setup...
insippo
Yesterday i check and looks mysensors lan gateway works good.
fets
- Domoticz version: 2.2969
I use for a couple of days an ESP with embedded sensors connected as lan gateway.
I 'm doing some tests and each time I reflash/restart my ESP, domoticz is not aware that connection is lost.
I have then to disable/enable the hardware in setup.
It seems that domoticz become aware in about 15 minutes. this is a long time since there is a Heartbeat msg sent every 10 seconds.
@gizmocuz, is there a way to reduce this reconnect duration ?
