Error: V_ID MySensors: Unknown/Invalid sensor type (42)
Posted: Friday 16 September 2016 9:54
by Flopp
RPi, version 3.5623
I got
Error: MySensors: Unknown/Invalid sensor type (42)
when using V_ID
This is my sketch
#include <SPI.h>
#include <MySensor.h>
#include <Wire.h>
#define NODE_ID 44
#define TEMP_CHILD 1
MySensor gw;
float temperature;
MyMessage tempMsg(TEMP_CHILD, V_ID);
void setup()
gw.begin(NULL,NODE_ID);
gw.sendSketchInfo("Minir", "1.0");
gw.present(TEMP_CHILD, S_TEMP);
void loop()
Serial.println("start");
temperature = 100.0;
Serial.print("temperature:");
Serial.print(temperature);
Serial.println("°");
gw.send(tempMsg.set(temperature, 1));
gw.sleep(5000);
Re: Error: MySensors: Unknown/Invalid sensor type (42)
Posted: Friday 16 September 2016 12:48
by sincze
I assume you are running a version of Mysensors < 2.0.0.
Why whould you need the V_ID ?
Presenting:
gw.present(CHILD_ID_TEMP, S_TEMP);
should be sufficient.
Posted: Friday 16 September 2016 12:52
by Flopp
sincze wrote:I assume you are running a version of Mysensors < 2.0.0.
Yes, I am using 1.5.1
sincze wrote:Why whould you need the V_ID ?
I was testing because at MySensors forum one user was telling that V_ID didn't work, the user got same Error message as I did
Posted: Friday 16 September 2016 12:58
by sincze
Ok, had to dig a bit in the code library.
// Startup and initialize MySensors library. Set callback for incoming messages.
gw.begin();
// Send the sketch version information to the gateway and Controller
gw.sendSketchInfo("Temperature Sensor", "1.1");
// Fetch the number of attached temperature sensors
numSensors = sensors.getDeviceCount();
// Present all sensors to controller
for (int i=0; i<numSensors && i<MAX_ATTACHED_DS18B20; i++) {
gw.present(i, S_TEMP);
Similar to yours without V_ID
So if you use S_TEMP without V_ID it still does not work??
Posted: Friday 16 September 2016 13:11
by Flopp
I can use S_TEMP but I need to declare tempMsg first and then I used V_ID for testing purpose.
If I use V_TEMP instead of V_ID it works.
My question was about the V_ID, why that Variable is not working. I have changed my first post to only ask about V_ID, to make it more clear
Posted: Friday 16 September 2016 13:25
by chrille
Flopp wrote:I can use S_TEMP but I need to declare tempMsg first and then I used V_ID for testing purpose.
Just to clarify - the usecase is to report the 1-wire address together with the temperature, so use V_TEMP to report the temperature and V_ID to report that 1-wire device addresss. This makes it easier do deploy a new installation and it's the only way to track which sensor have gone bad, if you loose one (unless you do a fixed matching of nodeid and address in the sketch)
- Jan
Posted: Friday 16 September 2016 18:18
by sincze
A yes, found the thread you are talking about.
https://forum.mysensors.org/topic/4834/ ... -sensors/7
Re: Error: V_ID MySensors: Unknown/Invalid sensor type (42)
Posted: Saturday 08 October 2016 19:44
by Flopp
anyone had same problem?
Posted: Sunday 09 October 2016 8:57
by gizmocuz
Domoticz does not use the V_ID value
Posted: Sunday 09 October 2016 9:09
by Flopp
Posted: Sunday 09 October 2016 9:18
by gizmocuz
Nope thats a reverse lookup function (GetMySensorsValueTypeStr)
Trust me (made the class) it's not implemented nor used, domoticz is using the nodeid/childid as ID
Posted: Sunday 09 October 2016 9:19
by Flopp
Ok, I trust you
Posted: Sunday 16 October 2016 3:39
by alexsh1
How can I report the distance so that it is displayed in km? It need it for a lightning sensor.
Unfortunately, it comes up in cm and V_UNIT_PREFIX does not work / not implemented in Domoticz.
Posted: Sunday 16 October 2016 8:25
by gizmocuz
Could you tell me which sensor ? (i am looking for one)
Maybe we can make it dynamic ? When it's over 100 we display it in meters, and when over 1000 in km ?
Posted: Tuesday 18 October 2016 14:14
by alexsh1
Something is wrong with my forum settings and I was not notified about you responding.
This is the sensor -
https://www.embeddedadventures.com/as39 ... -1016.html
It is based on AS3935
This is the thread on MySensors about it. My posted my sketch on it.
https://forum.mysensors.org/topic/880/s ... -sensor/48
There are several boards but based on the same chip.
I have the one from Embedded Adventures.
What I did now it that I changed domoticz.db/DeviceStatus sub-type from "27" to "1" and cm changed for km. Not sure if this is a permanent fix though.
I think there has to be two different types of "Distance". Parking sensors does not need km or even m, but needs cm or even mm. Lightning sensor / Visibility needs km and not m.
Posted: Tuesday 18 October 2016 17:42
by gizmocuz
I think you changed it to a visibility sensor ?
Maybe a dynamic label like i opt above will help ?
if <100 then cm
else if <1000 then meters
else km
i ordered a sensor to test with
It might mean that in the feature you might need to send 40000 for 40 km
Posted: Tuesday 18 October 2016 18:26
by alexsh1
Probably, it makes sense. I would suggest as follows:
if distance < 100 then cm
else if distance <10000 then meters
else km
this means 100 = 1m, 10000 = 100m, >10000 is > 0.1km
This is sketch. The distance can be multiplied easily:
#define MY_DEBUG
//#define MY_DEBUG_VERBOSE_SIGNING
// Enable and select radio type attached
#define MY_RF24_CE_PIN 7
#define MY_RF24_CS_PIN 8
#define MY_RADIO_NRF24
//#define MY_RADIO_RFM69
#define MY_NODE_ID 13
//Signing soft
//#define MY_SIGNING_SOFT
//#define MY_SIGNING_SOFT_RANDOMSEED_PIN 7
//#define MY_SIGNING_ATSHA204
//#define MY_SIGNING_REQUEST_SIGNATURES
#include <Wire.h>
#include <MySensors.h>
#include <AS3935.h> // AS3935 MOD-1016 by Embedded Adventures
volatile bool detected = false;
//-----------------IMPORTANT--------------------
//---------------CHANGE SETTINGS HERE-----------
#define IRQ_pin 2
#define AS3935_TUNE_CAPS 6 // <-- SET THIS VALUE TO THE NUMBER LISTED ON YOUR BOARD
#define AS3935_INDOORS 1 // AS3935_INDOORS=1 indoors, AS3935_INDOORS=0 outdoors
#define AS3935_NOISE_FLOOR 6
#define AS3935_ENABLE_DISTURBERS 1 // 0 or 1
#define CHILD_ID_DISTANCE 1
#define CHILD_ID_INTENSITY 2
#define CHILD_ID_STAT 3
MyMessage msgDist(CHILD_ID_DISTANCE, V_DISTANCE);
MyMessage Prefix(CHILD_ID_DISTANCE, V_UNIT_PREFIX);
MyMessage msgInt(CHILD_ID_INTENSITY, V_VAR5);
MyMessage msgStat(CHILD_ID_STAT, V_TEXT);
void setup()
Serial.begin(115200);
while (!Serial) {}
Serial.println("MOD-1016 (AS3935) Lightning Sensor");
Serial.println("beginning boot procedure....");
Wire.begin();
mod1016.init(IRQ_pin);
//Tune Caps, Set AFE, Set Noise Floor
//autoTuneCaps(IRQ_pin);
mod1016.setTuneCaps(AS3935_TUNE_CAPS);
delay(2);
#if AS3935_INDOORS == 1
mod1016.setIndoors();
#else
mod1016.setOutdoors();
#endif
delay(2);
mod1016.setNoiseFloor(AS3935_NOISE_FLOOR);
delay(2);
#if AS3935_ENABLE_DISTURBERS == 1
mod1016.enableDisturbers();
#else
mod1016.disableDisturbers();
#endif
//mod1016.calibrateRCO();
delay(2);
Serial.println("TUNE\tIN/OUT\tNOISEFLOOR");
Serial.print(mod1016.getTuneCaps(), HEX);
Serial.print("\t");
Serial.print(mod1016.getAFE(), BIN);
Serial.print("\t");
Serial.println(mod1016.getNoiseFloor(), HEX);
//Serial.print("\n");
pinMode(IRQ_pin, INPUT);
attachInterrupt(digitalPinToInterrupt(IRQ_pin), alert, RISING);
Serial.println("after interrupt");
// delay execution to allow chip to stabilize.
delay(1000);
void presentation() {
sendSketchInfo("Lightning Sensor MOD-1016", "1.0");
// Register all sensors to gw (they will be created as child devices)
present(CHILD_ID_DISTANCE, S_DISTANCE);
send(Prefix.set("km"));
present(CHILD_ID_INTENSITY, S_CUSTOM);
present(CHILD_ID_STAT, S_INFO);
void loop() {
if (detected) {
translateIRQ(mod1016.getIRQ());
detected = false;
void alert() {
detected = true;
void translateIRQ(uns8 irq) {
switch(irq) {
case 1:
Serial.println("Noise detected");
break;
case 4:
Serial.println("Disturber detected");
//send(msgStat.setSensor(CHILD_ID_STAT).set("Disturber detected"));
break;
case 8:
Serial.println("Lightning detected!");
printandsendToGW();
break;
void printandsendToGW() {
int distance = mod1016.calculateDistance();
unsigned int lightning_intensity = mod1016.getIntensity();
if (distance == -1)
Serial.println("Lightning out of range");
else if (distance == 1)
Serial.println("Distance not in table");
else if (distance == 0)
Serial.println("Lightning overhead") & send(msgStat.setSensor(CHILD_ID_STAT).set("Lightning overhead!"));
else {
Serial.print("Lightning ~");
Serial.print(distance);
Serial.println("km away\n");
Serial.print("Lightning Intensity: ");
Serial.println(lightning_intensity);
send(msgStat.setSensor(CHILD_ID_STAT).set("Lightning in a distance"));
send(msgDist.set(distance));
send(msgInt.set(lightning_intensity));
Posted: Tuesday 27 March 2018 14:54
by alexsh1
@GizMoCuz
Any news on this? Dynamic sensor would work or something like this send(Prefix.set("km")); (currently does not work in Domoticz)
