Page 1 of 3
HowTo: monitor QNAP NAS
Posted: Wednesday 08 January 2014 22:19
by mbliek
Anyone interested in monitoring HD temp and Free HD space for QNAP systems?
If so, I would write a how to.
Now in the WIKI: http://www.domoticz.com/wiki/NAS_Monitoring
Re: HowTo: monitor QNAP NAS
Posted: Wednesday 08 January 2014 23:37
by camillo777
Yes!! I did a couple of simple sh scripts for generic Linux I can publish as well
Posted: Thursday 09 January 2014 10:57
by andriej
Both of you, publish them.
Posted: Thursday 09 January 2014 15:15
by camillo777
Some scripts to monitor the Domoticz process:
#!/bin/sh
# Get Domoticz Process CPU
ps -C domoticz -o %cpu | tail -n +2
#!/bin/sh
# Get Domoticz Process Memory
ps -C domoticz -o %mem | tail -n +2
#!/bin/sh
# Get Domoticz Folder Size
du -shb /home/pi/camillo/domoticz-code | awk -F " " {'print $1'}
Posted: Thursday 09 January 2014 16:42
by mbliek
The script is changed, use the one on the WIKI page.
Here is my HowTo
First enable SNMP on your QNAP NAS:
http://docs.qnap.com/nas/en/index.html? ... ttings.htm
You can use V1/V2
And set a password (Community)
Then install SNMP on your RaspberryPi
sudo apt-get install snmpd
Reboot Pi
Check if SNMP is up and running:
snmpget -v 2c -c PASSWORD -O qv NASIPADDRESS 1.3.6.1.4.1.24681.1.2.11.1.3.1
You should get something like this:
"37 C/98 F"
Make 3 new virtual Temperature Sensors (NAS HD1, NAS HD2 and NAS Free HD)
And 1 new virtual Switch (NAS)
nas.sh (in domoticz/scripts/)
#!/bin/bash
# Settings
NASIP="00.00.00.00" # NAS IP Address
PASSWORD="password" # SNMP Password
DOMO_IP="00.00.00.00" # Domoticz IP Address
DOMO_PORT="0000" # Domoticz Port
# Check if NAS in online
PINGTIME=`ping -c 1 -q $NASIP | awk -F"/" '{print $5}' | xargs`
echo $PINGTIME
if expr "$PINGTIME" '>' 0
then
echo "NAS ON"
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=switchlight&idx=184&switchcmd=On"
# Temperature HD1
HDtemp1=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.24681.1.2.11.1.3.1 | cut -c 2-3`
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=181&nvalue=0&svalue=$HDtemp1"
# Temperature HD2
HDtemp2=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.24681.1.2.11.1.3.2 | cut -c 2-3`
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=182&nvalue=0&svalue=$HDtemp2"
# Remaining HD size
size=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.24681.1.2.17.1.5.1 | cut -c 2-7`
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=183&nvalue=0&svalue=$size"
echo "NAS OFF"
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=switchlight&idx=184&switchcmd=Off"
fi
Change the idx to your own idx
Make this script executable:
sudo chmod +x nas.sh
Try the script out:
./nas.sh
You should get something like:
1
NAS ON
HTTP/1.0 200 OK
Content-Length: 51
Content-Type: text/html;charset=UTF-8
Cache-Control: no-cache
Pragma: no-cache
"status" : "OK",
"title" : "SwitchLight"
HTTP/1.0 200 OK
Content-Length: 53
Pragma: no-cache
"status" : "OK",
"title" : "Update Device"
HTTP/1.0 200 OK
Content-Length: 53
Pragma: no-cache
"status" : "OK",
HTTP/1.0 200 OK
Content-Length: 53
Pragma: no-cache
"status" : "OK",
Make a new crontab job:
crontab -e
*/5 * * * * /home/pi/domoticz/scripts/nas.sh (= every 5 minutes)
Forgot to say
I did made a room called NAS and put all my virtual sensors and switch there.
Thats it, any question? Just ask.
Posted: Saturday 11 January 2014 23:47
by Jastrzi
mbliek thank you for this HOWTO, it's briliant!
As I have some issues with temp. of all my HDDs I start reporting Sys temp.
I've replaced one of yours command with following one:
snmpget -v 2c -c password -O qv NASIP 1.3.6.1.4.1.24681.1.2.6.0
This returns the Sys temperature.
Just FYI if somebody will looking for it.
Posted: Sunday 12 January 2014 9:42
by mbliek
I couldn't get my system temp. Will test it when I got home.
Posted: Sunday 12 January 2014 16:57
by mbliek
Thanks for that Jastrzi. Got my system temp now as well.
Will update my howto later
Posted: Saturday 08 February 2014 11:16
by gdekeijzer
Great stuff. One question, what is the 'Switch' used for?
Posted: Saturday 08 February 2014 12:28
by Jastrzi
Switch is showing you wheter Qnap is on or off
Posted: Monday 10 February 2014 18:05
by gdekeijzer
Oh, just status
Switching off / on your NAS would be not the best thing using a switch
Posted: Wednesday 12 February 2014 22:21
by mbliek
I added CPU temp and made a WIKI page for this.
Posted: Tuesday 06 May 2014 22:15
by kimhav
Great stuff! But, is there a limit to how many drives one could monitor with this script or with Domoticz; asking since you've only included 2 drives where I would need to monitor 4 drives?
Posted: Tuesday 06 May 2014 22:37
by mbliek
There is no limit. My NAS has only 2 drives, that's why this script includes 2 drives.
Posted: Tuesday 06 May 2014 23:34
by kimhav
Ok, Just copied and updated the script to monitor 4 drives. Only thing that I'm not getting to work is the NAS Free HD parameter; it comes out empty in the Device. But, assume that's due to device error as the input data isn't what is expected (temperatur);
<html><head><title>Bad Request</title></head><body><h1>400 Bad Request</h1></body></html>
Posted: Monday 12 May 2014 19:12
by brijoco
I was having the same problem so I put a few echo's in the script and got ...
>>> HD free: > 1.41 T <
HTTP/1.0 400 Bad Request
Content-Length: 89
<html><head><title>Bad Request</title></head><body><h1>400 Bad Request</h1></body></html>pi@PI-DOMO ~/domoticz/scripts $ ./brinas.sh
When I changed the 'cut -c 2-7' to 'cut -c 2-5' I got ...
>>> HD free: > 1.41 <
HTTP/1.0 200 OK
Content-Length: 53
Pragma: no-cache
"status" : "OK",
So, I am using the change in the cut as a work around until I can find what is the max content length and how it relates to the length of the string passed.
Any suggestions or pointers gratefully received.
Regards,
Posted: Thursday 22 May 2014 17:51
by kimhav
Using "cut -c 2-5" did not do the trick on my side; still error and no update.
Posted: Thursday 29 May 2014 19:27
by BobdeBouwer
Thanx for starting this, it is great for learning and reading!
I downloaded the MIB file from my QNAP TS219P admin pages, used the snmpB browser and "walked" some tree's.
That information will be nice to combine with Domoticz via the scripts and the WIKI HowTo.
I did not find a query for the system Fan speed, perhaps later.
My 2 cents:
First of all, the HDD queries makes the disk spin-up, so if you query them every 5 minutes they will never spin-down.
Secondly, some more variables to use.
$COMM is community string
$IP is QNAP NAS IP-address
#system CPU usage
snmpget -v 2c -c $COMM -O qv $IP 1.3.6.1.4.1.24681.1.2.1.0
#system total memory
snmpget -v 2c -c $COMM -O qv $IP 1.3.6.1.4.1.24681.1.2.2.0
#system free memory
snmpget -v 2c -c $COMM -O qv $IP 1.3.6.1.4.1.24681.1.2.3.0
#Uptime of network portion of system
snmpget -v 2c -c $COMM -O qv $IP 1.3.6.1.4.1.24681.1.2.4.0
#System uptime - fraction longer
snmpget -v 2c -c $COMM -O qv $IP 1.3.6.1.2.1.25.1.1.0
#System temp
snmpget -v 2c -c $COMM -O qv $IP 1.3.6.1.4.1.24681.1.2.6.0
Posted: Thursday 17 July 2014 16:10
by martjah
In the past the QNAP script made my domoticz crash a few times a week. I've added an extra check in my version, it checks if only numbers are returned, if not, then it does not update Domoticz with the new value. I did not make it for the free space check because i'm not using that part. Here is an example:
# Temperature CPU
CPUtemp=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.24681.1.2.6.0 | cut -c 2-3`
if [[ $CPUtemp == ?(-)+([0-9.]) ]]; then
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$CPU_TEMP_IDX&nvalue=0&svalue=$CPUtemp"
echo "Oeps, er komen niet alleen cijfers terug!"
fi
Posted: Sunday 21 September 2014 16:54
by BobdeBouwer
Hi All,
I was having some discussions with my QNAP NAS 219P as to why it would not spin down. A lot of reading can be done on this topic and long story short is that I decided to disable the cloud service and edit my CRONTAB (and reload it) with my maintanance window set to 21:00, most chances are that one ore more PC's are performing a back-up or are using shares anyway. To keep track on the spin up / down count I made a little script of bits and pieces that I would like to share here.
It uses a virtual device QNAP and a virtual counter on that virtual device. Via CURL and JSON I plan to update that counter once a day.
That way I can look at the spin up/ down count in Domoticz and keep track on irregularities when the disks fail to spin down.
The script is placed on one of the shares, pick your own spot.
Make it executable, plan it in Crontab (do try to get the maintanance together) and do not forget to reload CRON.
#reload crontab
crontab /etc/config/crontab
#restart cron
/etc/init.d/crond.sh restart
This is the script that runs on the QNAP:
#!/bin/sh
#Mind you this works with Domoticz and QNAP QTS 4.1.0 - Use at your own risk -
#In Domoticz - Define a virtual device then add a counter - make it visable and then adjust to counter type
#Search the Idx value in the devices list and set the number for IDN in this script
#Does require disk to spin bescause it is a script on disk - schedule in CRONTAB during maintanance window of create TMPFS
#edit the crontab file on the QNAP with your favorite editor /etc/config/crontab to your needs
#Make sure the script is exacutable
#To make it last - be sure to restart CRON /etc/init.d/crond.sh restart
# Declare Variables
DomoticzIP="192.168.X.ZZZ" # IP of Domoticz instance
Port="8080" # Port number of Domoticz listner
IDN="ZZ" # Device number of virtual switch in Domoticz
Disk="1" # Choose a disk from your QNAP NAS to query with get_hd_smartinfo
#Proceed only if Domoticz is around in network
if ping -c 1 $DomoticzIP &> /dev/null
then
echo "host found @" $DomoticzIP
regel=`/sbin/get_hd_smartinfo -d $Disk | /bin/grep Start_Stop_Count`
# echo $regel # uncomment to see what you found
# print third string as this holds the count we look for
ststop=` echo $regel | awk '{ print $3 }' `
echo "Start Stop Count of disk no." $Disk "=" $ststop # see what you found
# Post it to Domoticz
curl -s -i -H "Accept: application/json" "http://$DomoticzIP:$Port/json.htm?type=command¶m=udevice&idx=$IDN&svalue=$ststop"
echo "no host found @" $DomoticzIP
fi
#nice exit no matter what
exit 0
As an example My Crontab line to run it at 21:00 hrs :
# m h dom m dow cmd
00 21 * * * /share/<<sharename-you-picked>>/PostSpinUp.sh > /dev/null 2>&1
Hope this works for you.
