I bought a 433mhz Kerui siren like this one:
https://nl.aliexpress.com/item/Wireless ... d53e93e513
It is compatible with PT1527 and PT2262.
My config is a RasPi with the RFXcomE and this works fine with a lot of devices and switches. I tried a lot of types in the "add manual switch" box and a lot of this types are confirmed by the Kerui in "learning mode". When i add this swich i will get the siren on when i click off the switch but is does not go off.
Any suggestions? Thanks!
Kerui siren does go on, but does not go off
reindje
Re: Kerui siren does go on, but does not go off
Nobody any suggestions? Do i just have to buy a more expensive one like this one: https://nl.aliexpress.com/item/wireless ... 23575.html
Esteban
Hi, I was looking to find if this Siren was compatible and ran into this thread, did you ever get it to work?reindje wrote:Nobody any suggestions? Do i just have to buy a more expensive one like this one: https://nl.aliexpress.com/item/wireless ... 23575.html
Willem81
I have the same problem! On works well, but I cannot turn it off
Hmmm. I am looking to buy the same siren.
Just thinking. If you would also purchase compatible remote control you could program siren to turn on and off with remote. After that you would create a switch in domotics with recording keypress on remote for arm and disarm. After that you could use blocky to create a script to trigger siren on and off.
