Swiidinter: received timeout
Posted: Wednesday 14 September 2016 20:08
First of all, I'm totally new to Domoticz, but I've managed to set this up: Domoticz running on Raspberry Pi and I've added a Razberry from Zwave.me (http://razberry.z-wave.me/). I've also already added a virtual device for weather info, following a tutorial online. So I've found my way around Domoticz, but can't say I'm an expert.
I've now bought a Swiidinter (http://www.swiid.com/en/produits.html) and put it between a lamp and the mains. It works when I use it manually, but now I want to add it to Domoticz. But it doesn't seem to work, making me doubt if I'm doing it correctly. Also, I don't really know how to troubleshoot it.
This is what I did (I hope I translated correctly because my interface is in Dutch).
- Go to Settings -> Hardware
- Click Node management
- Choose the first option (add sensor or something like that)
- I get the spinner, and then push the tiny button on my Swiidinter
- The Swiidinter now blinks red and then stays red for two seconds, which should indicate that the pairing succeeded
- In Domoticz however, the spinner remains.
Now, when I go to the log, I see:
2016-09-14 20:02:09.843 New sensors allowed for 5 minutes...
2016-09-14 20:02:09.844 OpenZWave: Node Include command initiated...
2016-09-14 20:02:10.845 OpenZWave: Received timeout notification from HomeID: 3984402067, NodeID: 255 (0xff)
I've tried putting the lamp with the Swiidinter next to my Raspberry with the Zwave module, but it's the same.
What do these lines mean exactly? Also, a timeout after 1 second?
How can I fix this, or investigate it further? It must be possible, as I've seen other posts of people who have successfully set up Swiidinter.
