Error when updating
Posted: Monday 12 September 2016 13:04
by gennapium
I am trying to update my beta version but get this error:
/domoticz$ git pull
Updating fe8d04d..dceedb4
error: Your local changes to the following files would be overwritten by merge:
hardware/1Wire/1WireCommon.h
Please, commit your changes or stash them before you can merge.
Aborting
Can anyone help me with this ?
Re: Error when updating
Posted: Monday 12 September 2016 13:11
by Flopp
How did you update it?
I normally update from Setup menu.
From what version to what version are you trying to update?
Posted: Monday 12 September 2016 13:19
by gennapium
I do the update when logging in with putty, stop the domoticz server and give the "git pul"l command. This has Always worked fine.
But at the moment is is buiding after the "make" command so it is looking good i guess.I found a solotion on the internet that seems to be working.
Not working, i get this error:
domoticz@dmserver:~/domoticz$ make
[ 1%] Built target sqlite
[ 15%] Built target lua
-- Found Git: /usr/bin/git (found version "1.9.1")
[ 15%] Built target revisiontag
[ 23%] Built target mqtt
[ 23%] Built target domoticz_gch
Linking CXX executable domoticz
CMakeFiles/domoticz.dir/main/mainworker.cpp.o: In function `MainWorker::AddHardwareFromParams(int, std::string const&, bool, _eHardwareTypes, std::string const&, unsigned short, std::string const&, std::string const&, std::string const&, std::string const&, int, int, int, int, int, int, int, bool)':
mainworker.cpp:(.text+0x2b3e7): undefined reference to `CDaikin::CDaikin(int, std::string const&, unsigned short, std::string const&, std::string const&)'
collect2: error: ld returned 1 exit status
make[2]: *** [domoticz] Error 1
make[1]: *** [CMakeFiles/domoticz.dir/all] Error 2
make: *** [all] Error 2
Anyone ?
Posted: Monday 12 September 2016 13:20
by Flopp
If Domoticz is still working you can try to update from Domotiz Setup menu.
Posted: Monday 12 September 2016 13:21
by gennapium
Domoticz is not running anymore
Posted: Monday 12 September 2016 13:39
by gennapium
A new installation is giving this error:
[ 0%] Built target revisiontag
[ 14%] Built target lua
[ 15%] Built target sqlite
[ 15%] Built target domoticz_gch
Posted: Monday 12 September 2016 14:32
by gennapium
Anyone ?
Posted: Monday 12 September 2016 14:45
by Sneezydevil
You are not the first one today I heard about not being able to compile.
Maybe you can checkout the last commit before the implementation of Daikin.
git checkout 26e9b48
Then try compiling again.
Posted: Monday 12 September 2016 14:54
by gennapium
Thanks a lot Sneezydevil, that did the trick. Now compiling is working again.
Posted: Monday 12 September 2016 15:03
by Sneezydevil
Nice, remember to go back to the master when updating the next time.
git checkout master
That should do the trick.
Posted: Tuesday 13 September 2016 12:49
by remb0
already fixed. I see a fix for the daikin.
Posted: Saturday 15 October 2016 21:06
by thecosmicgate
same /again an updare issue :
Updating to server revision...
Fetching origin
HEAD is now at 9d81b24 Removed debug in Daikin module
-- Using builtin Mosquitto library
-- Compiling Revision #5770
-- Boost version: 1.61.0
-- Found the following Boost libraries:
-- thread
-- date_time
-- system
-- chrono
-- atomic
-- Linking against boost static libraries
-- ZLIB libraries found at: /usr/lib/x86_64-linux-gnu/libz.so
-- ZLIB includes found at: /usr/include
-- Curl libraries found at: /usr/lib/x86_64-linux-gnu/libcurl.so
-- Curl includes found at: /usr/include
-- LIBUSB found at: /usr/lib/x86_64-linux-gnu/libusb.so
-- /home/pim/open-zwave-read-only/libopenzwave.a
-- /usr/lib/x86_64-linux-gnu/libudev.so
-- ==== WiringPi include file (wiringPi.h) not found. GPIO support disabled.
-- ==== (Please follow http://wiringpi.com/download-and-install/ if you want to use GPIO.)
-- Not found telldus-core (telldus-core.h), not adding tellstick support
CMake Warning (dev) at CMakeLists.txt:151 (GET_DIRECTORY_PROPERTY):
Policy CMP0059 is not set: Do no treat DEFINITIONS as a built-in directory
property. Run "cmake --help-policy CMP0059" for policy details. Use the
cmake_policy command to set the policy and suppress this warning.
Call Stack (most recent call first):
CMakeLists.txt:608 (ADD_PRECOMPILED_HEADER)
This warning is for project developers. Use -Wno-dev to suppress it.
/usr/bin/c++ ;-O3;-DNDEBUG;-I/home/pim/domoticz/main;-I/usr/include;-I/usr/include;-I/usr/include;-I/usr/include;-I/home/pim/domoticz/hardware/openzwave;;-DBUILTIN_MQTT;-DHAVE_EXECINFO_H;-DWITH_LIBUSB;-DWWW_ENABLE_SSL;-DWITH_OPENZWAVE -x c++-header -o /home/pim/domoticz/stdafx.h.gch/.c++ /home/pim/domoticz/main/stdafx.h
-- Using static libgcc/libstdc++
-- Configuring done
-- Generating done
-- Build files have been written to: /home/pim/domoticz
-- Found Git: /usr/bin/git (found version "2.9.3")
[ 27%] Building CXX object CMakeFiles/domoticz.dir/hardware/ZWaveBase.cpp.o
cc1plus: warning: ./stdafx.h.gch/.c++: created by a different GCC executable
make[2]: *** No rule to make target '/usr/lib/x86_64-linux-gnu/libudev.so', needed by 'domoticz'. Stop.
CMakeFiles/Makefile2:103: recipe for target 'CMakeFiles/domoticz.dir/all' failed
Makefile:149: recipe for target 'all' failed
Posted: Monday 17 October 2016 11:30
by thecosmicgate
Still getting this error when try to build 5776 , somebody who can help me to solve this ?
Posted: Sunday 30 October 2016 11:39
by thecosmicgate
trying to build version 3.5837, but still :
Fetching origin
remote: Counting objects: 218, done.
remote: Compressing objects: 100% (110/110), done.
remote: Total 218 (delta 100), reused 68 (delta 68), pack-reused 39
Receiving objects: 100% (218/218), 1.40 MiB | 245.00 KiB/s, done.
Resolving deltas: 100% (110/110), completed with 34 local objects.
From https://github.com/domoticz/domoticz
ee1170c..591a669 master -> origin/master
79e9201..0e830cc Websockets-refactored -> origin/Websockets-refactored
* [new tag] 3.5837 -> 3.5837
* [new tag] 3.5834 -> 3.5834
HEAD is now at 591a669 - Fixed: Blockly/Lua, FOR and RANDOM are now again in minutes (Fixes commit #927)
-- Compiling Revision #5837
-- thread
-- date_time
-- system
-- chrono
-- atomic
CMakeLists.txt:609 (ADD_PRECOMPILED_HEADER)
-- Configuring done
-- Generating done
[ 1%] Built target revisiontag
[ 2%] Built target domoticz_gch
[ 16%] Built target lua
[ 24%] Built target mqtt
[ 69%] Building CXX object CMakeFiles/domoticz.dir/tcpserver/TCPServer.cpp.o
[ 69%] Building CXX object CMakeFiles/domoticz.dir/webserver/proxyclient.cpp.o
Compile failed!
What can i do to solve this ?
Posted: Sunday 30 October 2016 11:47
by jumbotroll
thecosmicgate wrote:trying to build version 3.5837, but still :
Fetching origin
-- thread
-- date_time
-- system
-- chrono
-- atomic
-- Configuring done
-- Generating done
Compile failed!
Try to install libudev-dev before compiling.
sudo apt-get install libudev-dev
Posted: Sunday 30 October 2016 20:51
by thecosmicgate
jumbotroll wrote:thecosmicgate wrote:trying to build version 3.5837, but still :
Fetching origin
-- thread
-- date_time
-- system
-- chrono
-- atomic
-- Configuring done
-- Generating done
Compile failed!
done :
Reading package lists... Done
Building dependency tree
Reading state information... Done
libudev-dev is already the newest version (231-9git1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Posted: Sunday 06 November 2016 20:30
by thecosmicgate
So I still didn't solve this ? Are there any more clue's?
