Cresta TX 320 stops transmitting
Posted: Sunday 11 September 2016 16:30
by jackisidore
I have two Cresta 320 thermo-hygro meters which simply stop transmitting. The unit works LED flashes, fresh batteries, reset button. no signal transmitted to domoticz. The other Crestas work normally
Does anyone have an idea how to fix this???
Re: Cresta TX 320 stops transmitting
Posted: Sunday 11 September 2016 16:46
by SweetPants
If you replaced batteries, they probably are different devices for Domoticz now. Have you tried "Accept New Hardware"?
Posted: Sunday 11 September 2016 16:51
by jackisidore
I recently added a new 320. It was visible in the devices page as a unused device. This one stops transmitting and never shows itself as a unused device.
Posted: Sunday 11 September 2016 17:43
by SweetPants
jackisidore wrote:This one stops transmitting and never shows itself as a unused device.
Does RFXmanager see the device, (assuming you have a RFXcom)?
Posted: Sunday 11 September 2016 18:27
by jackisidore
Good idea! I need to find my old rfxcom to test this
Posted: Tuesday 13 September 2016 18:15
by jackisidore
I'm not sure but if you replace batteries or press reset the address changes. In this case I ended up with two crestas with the same address.
Posted: Tuesday 13 September 2016 18:36
by Stuntteam
Could it be that the two cresta's are transmitting at the same moment, resulting in one (the weakest signal) not being visible..
Posted: Tuesday 13 September 2016 18:40
by jackisidore
No they transmitted on the same adress the domoticz log showed jumping temp readings. I didnt notice this at first. Selecting a different unit and pressing reset on the cresta solved it.
Posted: Thursday 15 September 2016 18:23
by SweetPants
Can you mark the topic solved?
