pool temperature sensor TFA 30.3216.20
Posted: Thursday 08 September 2016 11:48
by Dirkie
I hava a pool temperature sensor TFA 30.3216.20 installed. At my devices it is shown as a TFA 30.3133 with a temperature of 0 degrees celcius and it is actualy 27 at this moment 8-)
Is there a method to change the reading so the correct values are shown?
Devices: Synology diskstation; RFXtrx433
Re: pool temperature sensor TFA 30.3216.20
Posted: Thursday 08 September 2016 19:07
by Dennist1985
Click the temperature tab.
Then click edit from your pool sensor and type 27 in the adjustment box.
Now it's always showing 27 degrees more then what he measuring.
Posted: Thursday 08 September 2016 20:52
by Dirkie
I've tried this already but the temperature doesn'nt change in domoticz when it changes in the pool...
Posted: Thursday 08 September 2016 21:03
by Derik
Show some screendumps...
Posted: Thursday 08 September 2016 21:18
by Dirkie
this is how the sensor is recognized by Domoticz
as I wrote eralier, donoticz thinks it is a 30.3133 insted of a 30.3216.20
Posted: Thursday 13 October 2016 15:05
by ervine
I have the same unit, also recognized as a 3133. In my case however temp readings work.
Posted: Thursday 13 October 2016 15:41
by b_weijenberg
The 30.3216.20 for the TFA 30.3056.10 is supported in Ext2 firmware version 1007 for the RFXtrx433E.
Enable the Oregon protocol for this TFA sensor!
On request a Type1 firmware for the RFXtrx433 can be provided by RFXCOM.
Posted: Thursday 25 May 2017 21:32
by Derik
mmm did have last year this sensor working...
Now the summer is here..
I try to add the sensor again.
See the value on the screen.
New battery
pus the tx button servel time.
Replace new battery..
Set the good protocol...
No sensor...
Bert where do i go wrong??
Think to much protocols enabled....
Only witch 2 hate each other?
Posted: Friday 26 May 2017 8:53
by b_weijenberg
check with RFXmngr if the sensor is received with only TFA enabled
