Show Nefit Easy temperature Topic is solved
tricodoro
Post by tricodoro »
I managed to install the Nefit Easy Server and got all the devices installed. Now almost everything shows nicely in the Utilities tab and 'Clock Mode' in the Switches tab. Almost everything, because the temperature values are not shown anywhere... :?
I can add the temperatures to a floorplan and have them shown there, but my question really is: why aren't the displayed in the Temperature tab?
Thanks for helping out!
SweetPants
Re: Show Nefit Easy temperature
Post by SweetPants »
Hmm, I have all (inside/outside/flow temp) under the Temperature tab. Sure you enabled the device as used?
tricodoro
Post by tricodoro »
Yes, I have set them all as 'Used'. Otherwise - I guess - I wouldn't be able to add them to a floorplan...
See here for the devices settings:
SweetPants
Mine shows...
Cleared your browser cache?
tricodoro
Post by tricodoro »
Changed over from Safari to Chrome and that did the trick! Thanks!!
But Browser Cache Refresh doesn't work:
Caching error.png (43.18 KiB) Viewed 2122 times
SweetPants
tricodoro wrote:But Browser Cache Refresh doesn't work: Caching error.png
That's 'normal' when using https
