I'm willing to create an irrigation system for my balcony (where I do not have a water valve, so I'll use a 20lt tank) to irrigate/water drop some small plants.
All plants are in separate vases (4) and in my head I would like to irrigate on demand any vase.
So I suppose I would need 4 ESP8266 humidity sensor, 4 electro valves, and a pump, a flood sensor (for the empty tank)
I suppose the water flow would be like:
TANK
--> Tank Electrovalve
--> Pump
Electrovalve 1 --> Vase 1
Electrovalve 2 --> Vase 2
Electrovalve 3 --> Vase 1
Electrovalve 4 --> Vase 1
back in the TANKbefore stop the punp and close the tank valve, it should check if other valves are open
If the tank gets empty, stop everything and send a notification
I would like to care about the scripting (Challenges must be accepted, not delegate to others
I have the first concern about Hardware: I assume I would need a 8realy board, but what about inputs? does RBpi3 has enough I/O?! Any suggestions for the board shall I use to handle all INs and OUTs?
if it is "safe" to use the same raspberry used for the server or use another one and configure it as a remote server? (I actually have a RBPi3 that can be used)
thanks a lot for all suggestions and help
Ciao
M
