sensor DHT22 on Fibaro Universal Sensor, is possible?
Posted: Wednesday 31 August 2016 16:43
by bigpea
as you know, is possible to use the sensor DHT22 on the Fibaro Universal Sensor (http://manuals.fibaro.com/binary-sensor/)?
In the manual just talking only for DS18B20 sensor, but i want to know also the humidity percentage.
Thanks.
Re: sensor DHT22 on Fibaro Universal Sensor, is possible?
Posted: Wednesday 31 August 2016 19:45
by LouiS22
I really don't think it's possible.
Posted: Wednesday 31 August 2016 21:17
by mischa
Although the DHT-22 uses a single-wire to send data it is not Dallas One Wire compatible! You can only use a DS18B20 on the universal sensor.
If you want to measure humidity then use the DHT-22 with Mysensors for example.
Posted: Thursday 01 September 2016 10:00
by bigpea
ok thanks, i will start my research :)
Posted: Thursday 01 September 2016 10:24
by blackdog65
Hi bigpea,
I use esp8266 now for all my temp/humidity sensing (except where a unit has built in sensors) and I find them to be very cheap and reliable.
See http://www.esp8266.nu/index.php/HumiditySensor for more information.
I'm currently building an en-suite bathroom between my 2 boy's rooms and have an esp8266 12e controlling the lights, heated mirror, extractor fan, and 2 door locks. It also runs a DHT22 in the shower cubicle that will decide when to run the extractor fan.
I have a few Fibaro Universal Sensors fitted but I'm replacing them with the ESP units.
I'm a bit disappointed with the binary sensors as they have so much potential... if you could control the outputs! :twisted: :x
Good luck
Sean :D
Posted: Thursday 01 September 2016 10:55
by bigpea
very good I like it!
So, simply, I can:
- buy the esp8266 module;
- buy dht22 sensor;
- change firmware of esp8266 with ESP Easy;
- link these two;
- add in domoticz a new hardware "MySensorGateway with LAN Interface" (but i will use the WiFi, is correct?)
It's all?
Posted: Thursday 01 September 2016 12:39
by blackdog65
Close,
the last steps are
- create a "Dummy" in hardware (mine is called "ESP")
- create a virtual temp/humidity sensor in "ESP" and note the device idx
- set domoticz ip parameters in espeasy
- set device idx in espeasy
The esp unit will then send regular readings to the virtual device... job done ;)
The big bonus is that the esp has further GPIO pins available so a spare can be used to control a relay.
i.e. Humidity >50% turn on fan. This is done again with a virtual switch (simple on/off) from the "ESP" hardware dummy and a On/Off Action command such as
http://ESP_IP_ADDRESS/control?cmd=GPIO,2,0
http://ESP_IP_ADDRESS/control?cmd=GPIO,2,1
to toggle (in this example) GPIO pin 2 to operate a relay.
Posted: Thursday 01 September 2016 12:42
by bigpea
ok perfect, many thanks!
Posted: Thursday 01 September 2016 12:52
by blackdog65
If you do go for the esp route,
I'd recommend starting with one of these https://www.amazon.co.uk/HiLetgo-NodeMC ... 66+nodemcu to try as they have 5v as well as 3v3, usb for power, usb for flashing rather than an extra seperate pcb and extra gpios.
