I have a Debian 8 VM running in Virtualbox on Windows with Domoticz V3.552 installed including openzwave. Hardware I use; Aeonlabs Zstick Gen5, Aeonlabs Smartswitch 6. I have been able to include two switches to the zstick. However, after the initial valus after a reboot, the values are not getting updated. I tried to enable polling on the switches, but this did not work. Switches are both assigned to group 1. Checking the logs shows the following: "016-08-28 13:20:38.984 OpenZWave: Received timeout notification from HomeID: 3313325095, NodeID: 3 (0x03)", according to a Google search I did, this should mean that the switches are too far away from eachother/the controller. But that seems a bit strong to me since at least one of those switches is within two meters of the controller. I have setup udev rules. Could someone please help me with solving this issue? Thanks!
Edit:
Just tested with HomeSeer and everything works. Why doesnt my Domoticz installation work?
Switches not updating
- Egregius
- Domoticz version: v2024.7
Re: Switches not updating
Haven't you posted the same text at http://www.domoticz.com/forum/viewtopic ... 592#p94592?
