Razberry Raspberry3 Domoticz
Ricolaman
Post by Ricolaman »
Hello everybody!
New in the forum after some searches, I didn't find anything on the forum to help me.
I bought a new Pi3 installed last version of Domoticz.
some weeks after bought a razberry cardboard (supposed to work on Pi3) and installed It on Domoticz.
As I've seen I disabled BT on Pi. did It
Nothing works . I tried to add a temperature captor (fibaro), but nothing pop up in Domoticz control panel.
I don't feel I did the right things in the right timing.
Do you know if there is a webpage that shows me how to proceed step by step to make a clean install?
I'm a really newby and honestly I don't know where to start.
C.R.
sisaenkov
Domoticz version: 3.8
Re: Razberry Raspberry3 Domoticz
Post by sisaenkov »
First you must setup Z-Way for adding necessary settings.
wget -q -O - razberry.z-wave.me/install | sudo bash
After that disable z-way and reboot RPi:
update-rc.d z-way-server disable
Now you can install and setup domoticz.
Ricolaman
Post by Ricolaman »
Thanks.
So you mean I need to format my sd card and reinstall that way.
Thanks for your help.
I will let you know
C.R.
Ricolaman
Post by Ricolaman »
Do I need to install Z-way upon a raspbian by instence?
sisaenkov
Post by sisaenkov »
Ricolaman wrote:Thanks.
C.R.
You don't need to format sd card. You can install Z-Way as is on your current raspbian or another OS.
Ricolaman
Post by Ricolaman »
Thanks,
Currently I have only installed domoticz that include raspbian, I guess.
I want to to a very new clean installation.
Can I install Raspbian jesse Lite instead of the full version? It's liter.
Thanks.
C.R.
