CURL : get rain data, save to file and read/process line by line
Posted: Monday 29 August 2016 23:59
Hi Folks,
I'm kinda stuck with the curl-part in the "IsItGonnaRain" function. (see this topic)
This scripts gets data from "Buienradar" and should save this into a tmp file
Next it should read this file line by line to process the data.
I am under the impression that the data/file is not saved actually.
Being no-expert in LUA, some help will be very welcome
here's part of my code
The debug result actually shows the content from the file, the content however isn't updated as you can see by the time.
Here's the debug result
function IsItGonnaRain(latitude,longitude,tempfilename,minutesinfuture,debug)
local averagerain = 0
local totalrain = 0
local rainlines = 0
-- construct the request URL
local url = 'http://gps.buienradar.nl/getrr.php?lat='..latitude..'&lon='..longitude
if (debug == 1) then print("| Request URL .............. : " .. url) end
-- now get the data
local trigger_action = 'curl -o '..tempfilename..' "'..url..'"' -- -s for Silent (no error messages) and -o for Write output to file instead of stdout.
handle = os.execute(trigger_action)
print("| Trigger action ........... : " .. trigger_action)
if handle then
print("| CURL Data request ........ : Success")
print("! CURL Data request ........ : Failed")
file = io.open(tempfilename, "r")
-- now analyse the received lines, format is like 000|15:30 per line.
while true do
line = file:read("*line")
if not line then break end
if (debug == 1) then print("| Rain data (line) ......... : " .. line) end
2016-08-29 23:56:00.509 LUA: +--------------------------------------------------+
2016-08-29 23:56:00.509 LUA: | =============== IS IT GONNA RAIN =============== |
2016-08-29 23:56:00.509 LUA: | Request URL .............. : http://gps.buienradar.nl/getrr.php?lat=52.326080&lon=5.600445
2016-08-29 23:56:00.595 LUA: | Trigger action ........... : curl -o /home/pi/domoticz/scripts/tmp/rain.tmp "http://gps.buienradar.nl/getrr.php?lat=52.326080&lon=5.600445"
2016-08-29 23:56:00.596 LUA: | CURL Data request ........ : Success
2016-08-29 [color=#FF0000]23:56[/color]:00.596 LUA: | Rain data (line) ......... : 000|[color=#FF0000]19:45[/color]
2016-08-29 23:56:00.596 LUA: | Rain data # lines ........ : 0
2016-08-29 23:56:00.596 LUA: | Total rain ............... : 0
