Clear Command list after command
Posted: Monday 29 August 2016 20:16
Hi there,
Clearly when you send a command in the command array it is continually reapplied from that point. Is there any way to stop this from happening?
If for example I set a light to off using LUA it then becomes impossible to turn the light back on manually. That just is not going to work for me I need to be able to influence the state of the device and then allow it to control itself from there.
Am I doing something wrong? or is there another way to achieve turning off a light?
Have to say I struggled to figure out how to dimm a light. Eventually worked out the "Set Level: xx %" string. Is there a definitive list of these somewhere as if there is I could not find it.
Many thanks for any help you can give.
