Kaku Doorbell Blockly
Posted: Monday 29 August 2016 16:54
by Cletus
I've searched high and low for the answer but i can't find the answer on it, maybe you guys are able to help out.
I have a KaKu doorbell ACDB-6600AC which is linked to the default doorbutton outside. I learned the system it's button and it sees it in Domoticz, i can press the button on the webgui and the chime goes off (I use RFLink). Now here is the difficult part.
I want to get the doorbell to send a notification to my phone when its pressed at all times, this i did thru the notifications section of the switch. All good.
Then i want to turn on my hall lights and outside light when people are pressing the doorbell. Normally this should not be an issue i guess but this doorbell uses the Group On command and this is all it is using. No Group Off or On/Off state. The only state it gives even when pressed is the Group On state.
Now i can't build a blockly based on do the lights after sunset because the lights will go on and off every 30 seconds or so because the event is constantly triggered.
This is what i build:
A scene called Dur (names are subject to change
) Where my outside lights and hall lights go on.
Blockly (Please note that i'm testing during the day so hence the fact that sunset is equal or smaller than):
Does anyone know what to do?
Thanks! Regards Paul
Re: Kaku Doorbell Blockly
Posted: Monday 29 August 2016 19:12
by blackdog65
Hi Paul,
I don't use KaKu but I have LightwaveRF/Siemens doorbells (4 of) and my blockly scripts use "On" instead of "Group On". Maybe that will work for you too? Worth a try
Sean
Posted: Monday 29 August 2016 19:25
by gennapium
I agree, you should use "On" instead of "Group On"
Posted: Monday 29 August 2016 19:29
by Egregius
Look at the history log of 'Deurbel' to see what is used.
Also, the light will only go on in the evening after sunset. You should use time < sunrise OR time > sunset
Btw, the command 'group on' or just 'On' is a setting...
Posted: Tuesday 30 August 2016 8:49
by Cletus
The state of the doorbell in the log is "Group On" and this doesnt change when pressed in the Log, or should i connect the doorbell chime instead of the button on the front door? If I use On will this work? Because the state only is "On" and not "Group On"
Posted: Tuesday 30 August 2016 9:18
by Egregius
You could try change the setting in settings -> other
Or alter your if statement to have IF deurbel != Off
Posted: Tuesday 30 August 2016 9:43
by Cletus
I tried that in the settings, changed it from Group On to On but the doorbell stays on Group On or do i need to delete the Device and relink it in that case?
Posted: Tuesday 30 August 2016 10:14
by Egregius
Have you tried changing your IF? That should also do it.
Posted: Tuesday 30 August 2016 10:16
by Cletus
Sorry quite new here and also with the Blockly stuff, can you elaborate how to exactly do that?
MAny thanks!
Posted: Tuesday 30 August 2016 10:28
by Cletus
Just tested out to change the Blockly to On but this doesnt seem to trigger the event system:
Below is the Doorbell pressed with the Blockly with the
On switch.
2016-08-30 10:24:05.794 User: Admin initiated a switch command
2016-08-30 10:24:05.795 RFLink Sending: 10;NewKaku;1473c5a;1;ALLON (Doorbell)
2016-08-30 10:24:06.742 Notification sent (email) => Success
2016-08-30 10:24:12.383 Kodi Notification (192.168.2.20:9777, TTL 5): Deurbel, Deurbel!, Icon /home/pi/domoticz/www/images/doorbell48.png
2016-08-30 10:24:12.384 Notification sent (kodi) => Success
2016-08-30 10:24:06.740 (RFLink 433MHz) Light/Switch (Deurbel)
Group On switch.
2016-08-30 10:25:01.896 User: Admin initiated a switch command
2016-08-30 10:25:01.897 RFLink Sending: 10;NewKaku;1473c5a;1;ALLON (Doorbell)
2016-08-30 10:25:02.865 Notification sent (email) => Success
2016-08-30 10:25:03.010 Kodi Notification (192.168.2.20:9777, TTL 5): Deurbel, Deurbel!, Icon /home/pi/domoticz/www/images/doorbell48.png
2016-08-30 10:25:03.011 Notification sent (kodi) => Success
2016-08-30 10:25:03.015 EventSystem: Event triggered: Deurbell_1
2016-08-30 10:25:02.862 (RFLink 433MHz) Light/Switch (Deurbel)
2016-08-30 10:25:03.243 Activating Scene/Group: [$Deurbel]
2016-08-30 10:25:03.244 Activating Scene/Group Device: Buitenlamp (On)
2016-08-30 10:25:03.245 RFLink Sending: 10;NewKaku;13d6ffa;9;ON
2016-08-30 10:25:04.160 (RFLink 433MHz) Light/Switch (Buitenlamp)
2016-08-30 10:25:04.168 Delaying switch [Buitenlamp] action (Off) for 120 seconds
2016-08-30 10:25:04.219 Activating Scene/Group Device: Ganglicht (On)
2016-08-30 10:25:04.219 RFLink Sending: 10;NewKaku;13d6ffa;a;ON
2016-08-30 10:25:05.156 (RFLink 433MHz) Light/Switch (Ganglicht)
2016-08-30 10:25:05.167 Delaying switch [Ganglicht] action (Off) for 120 seconds
Posted: Tuesday 30 August 2016 10:37
by Cletus
I changed the blockly to: Please note that the statement is equal or less because i'm testing now
Will change that to equal or more when working.
But now the event system generates the following stuff in the log. Every minute the doorbell mechanism is triggered... Whilst not pressing anything, but when i press it the logfile generates that statement.
2016-08-30 10:30:25.406 EventSystem: reset all events...
2016-08-30 10:31:00.301 EventSystem: Event triggered: Deurbell_2
2016-08-30 10:31:01.093 Activating Scene/Group: [$Deurbel]
2016-08-30 10:31:01.094 Activating Scene/Group Device: Buitenlamp (On)
2016-08-30 10:31:01.095 RFLink Sending: 10;NewKaku;13d6ffa;9;ON
2016-08-30 10:31:02.008 (RFLink 433MHz) Light/Switch (Buitenlamp)
2016-08-30 10:31:02.015 Delaying switch [Buitenlamp] action (Off) for 120 seconds
2016-08-30 10:31:02.066 Activating Scene/Group Device: Ganglicht (On)
2016-08-30 10:31:02.066 RFLink Sending: 10;NewKaku;13d6ffa;a;ON
2016-08-30 10:31:03.003 (RFLink 433MHz) Light/Switch (Ganglicht)
2016-08-30 10:31:03.013 Delaying switch [Ganglicht] action (Off) for 120 seconds
2016-08-30 10:32:00.319 EventSystem: Event triggered: Deurbell_2
2016-08-30 10:32:01.069 Activating Scene/Group: [$Deurbel]
2016-08-30 10:32:01.070 Activating Scene/Group Device: Buitenlamp (On)
2016-08-30 10:32:01.071 RFLink Sending: 10;NewKaku;13d6ffa;9;ON
2016-08-30 10:32:01.977 (RFLink 433MHz) Light/Switch (Buitenlamp)
2016-08-30 10:32:01.984 Delaying switch [Buitenlamp] action (Off) for 120 seconds
2016-08-30 10:32:02.035 Activating Scene/Group Device: Ganglicht (On)
2016-08-30 10:32:02.035 RFLink Sending: 10;NewKaku;13d6ffa;a;ON
2016-08-30 10:32:02.977 (RFLink 433MHz) Light/Switch (Ganglicht)
2016-08-30 10:32:02.985 Delaying switch [Ganglicht] action (Off) for 120 seconds
2016-08-30 10:33:00.337 EventSystem: Event triggered: Deurbell_2
2016-08-30 10:33:01.042 Activating Scene/Group: [$Deurbel]
2016-08-30 10:33:01.043 Activating Scene/Group Device: Buitenlamp (On)
2016-08-30 10:33:01.043 RFLink Sending: 10;NewKaku;13d6ffa;9;ON
2016-08-30 10:33:01.996 (RFLink 433MHz) Light/Switch (Buitenlamp)
2016-08-30 10:33:02.002 Delaying switch [Buitenlamp] action (Off) for 120 seconds
2016-08-30 10:33:02.053 Activating Scene/Group Device: Ganglicht (On)
2016-08-30 10:33:02.053 RFLink Sending: 10;NewKaku;13d6ffa;a;ON
2016-08-30 10:33:02.995 (RFLink 433MHz) Light/Switch (Ganglicht)
2016-08-30 10:33:03.004 Delaying switch [Ganglicht] action (Off) for 120 seconds
2016-08-30 10:33:07.055 RFLink Sending: 10;NewKaku;13d6ffa;9;OFF
2016-08-30 10:33:07.987 (RFLink 433MHz) Light/Switch (Buitenlamp)
2016-08-30 10:33:07.994 RFLink Sending: 10;NewKaku;13d6ffa;a;OFF
2016-08-30 10:33:08.901 (RFLink 433MHz) Light/Switch (Ganglicht)
2016-08-30 10:34:50.744 RFLink Sending: 10;NewKaku;1473c5a;1;ALLON
2016-08-30 10:34:51.663 Notification sent (email) => Success
2016-08-30 10:34:57.314 Kodi Notification (192.168.2.20:9777, TTL 5): Deurbel, Deurbel!, Icon /home/pi/domoticz/www/images/doorbell48.png
2016-08-30 10:34:57.315 Notification sent (kodi) => Success
2016-08-30 10:34:57.319 Deurbel Test Do and Else If
2016-08-30 10:34:57.319 EventSystem: Event triggered: Deurbell_1
2016-08-30 10:34:51.662 (RFLink 433MHz) Light/Switch (Deurbel)
2016-08-30 10:35:00.372 EventSystem: Event triggered: Deurbell_2
2016-08-30 10:35:00.748 Activating Scene/Group: [$Deurbel]
2016-08-30 10:35:00.749 Activating Scene/Group Device: Buitenlamp (On)
2016-08-30 10:35:00.749 RFLink Sending: 10;NewKaku;13d6ffa;9;ON
2016-08-30 10:35:01.655 (RFLink 433MHz) Light/Switch (Buitenlamp)
2016-08-30 10:35:01.663 Delaying switch [Buitenlamp] action (Off) for 120 seconds
2016-08-30 10:35:01.713 Activating Scene/Group Device: Ganglicht (On)
2016-08-30 10:35:01.714 RFLink Sending: 10;NewKaku;13d6ffa;a;ON
2016-08-30 10:35:02.654 (RFLink 433MHz) Light/Switch (Ganglicht)
2016-08-30 10:35:02.665 Delaying switch [Ganglicht] action (Off) for 120 seconds
Posted: Tuesday 30 August 2016 11:23
by Egregius
Every minute?
You have it as time script instead of device script.
Have you seen the ! in IF deurbel != Off? That means IF deurbel is different then Off
Posted: Tuesday 30 August 2016 11:42
by Cletus
Thanks again for your answer to a complete Blockly / Programming n00b
Not sure what you mean with the != because i can't see the ! anywhere, i only can choose:
(Couldnt find this one but its the one with the Equal sign with a slash thru it) Means Is not equal i think.
And what do you mean with changing it to a device script instead of a time script?
Posted: Tuesday 30 August 2016 11:53
by Egregius
I think you blockly is now created as time wich means it run's every minute.
It should be created as device so it only runs when a device is updated.
Read the wiki about the event system for explanation about that.
Could be that blockly uses the equal sign with a slash through it, I don't use blockly.
Posted: Tuesday 30 August 2016 12:07
by blackdog65
Hi again Paul,
I would say your script has 2 halves
"If X = a And Y = b"
"Do Z"
So you can break it down, I would (and I do) create some virtual switches to replace some of the devices in your script.
This way you can test your doorbell by getting it to turn on (or off) a virtual switch without the sunset parameter. If this works, you now know if your doorbell responds to "ON" "Group On" or "Off" or whatever.
Then you can add the "Real" devices into the script one at a time as you test.
I hope this helps, I know how frustrating it can be! But once it starts working for you there's a lot of fun to be had.
Sean
Posted: Tuesday 30 August 2016 14:18
by Cletus
Wow, that simple... I checked egregius his option and changed the blockly type to device instead of type All where it checks the device state indeed but also runs it every minute. It seems to work perfectly now! Does anyone see anything that should not be?
Blockly:
Thanks for all your answers!!!
