Domoticz remote question
Posted: Saturday 27 August 2016 12:05
by gennapium
I have the latest beta version running om a Ubuntu 14.04 server and on a Raspberry Pi3. I have noticed that these two beta's do no have the same version. I wat to make a remote connection from the linux to the pi. But the documentation clearly says the versions have to be the same.
Could someone help me with this ?
Re: Domoticz remote question
Posted: Saturday 27 August 2016 13:05
by SweetPants
gennapium wrote:Could someone help me with this ?
Well if the documentation says they have to be the same, you need to update one of your installations
Posted: Saturday 27 August 2016 13:08
by gennapium
I did update both to the latest beta version but still they are not the same versions
Posted: Saturday 27 August 2016 13:10
by gennapium
Some more info,
Ubuntu is running Domoticz 3.5559
Pi3 is running Domoticz 3.5541
Posted: Sunday 28 August 2016 9:40
by SweetPants
gennapium wrote:Ubuntu is running Domoticz 3.5559
Looks like you complite fom source on one system?
If so, then you better compile from source to lineup your versions on both systems
Posted: Sunday 28 August 2016 10:34
by gizmocuz
Version mismatch is not relevant between these versions.
Sometimes there is an internal data structure change (last time was a half year ago), and then you need to have equal versions
What is important, is that both systems are using the same endianess (little or big endian)
Posted: Sunday 28 August 2016 13:25
by gennapium
Ok great,
Now i can start buiding a new domoticz system with a remote Pi
Posted: Sunday 28 August 2016 17:50
by Derik
Dear Gizmocuz..
Is it possible @ the moment to use more than 1 slave?
Posted: Monday 29 August 2016 19:40
by SweetPants
Derik wrote:Is it possible @ the moment to use more than 1 slave?
Did you search the wiki?
http://www.domoticz.com/wiki/Setting_up_Device_sharing
Posted: Monday 29 August 2016 19:47
by Derik
Yep..
Only did you try to have 2 remotes....
And then??
Posted: Monday 29 August 2016 21:22
by SweetPants
Derik wrote:Only did you try to have 2 remotes....
And then??
Yep,
log shows
2016-08-29 21:17:14.492 Domoticz: TCP connected to:
192.168.24.15:6144
2016-08-29 21:17:14.494 Domoticz: TCP connected to:
192.168.24.16:6144
So i tend to believe the Wiki
