sensor data to shell script
Posted: Thursday 25 August 2016 10:18
by Robban
I wonder how i retreive a sensordata (ex temperature) to a shell script?
i want my pi to say the temperature in a scenario
Robert
Re: sensor data to shell script
Posted: Thursday 25 August 2016 10:27
by Egregius
Did you look at the json commands in the wiki?
Maybe this is a starting point. I use this script to let my iMac go to sleep depending on 3 switches in Domoticz:
#!/bin/bash
function jsonValue() {
KEY=$1
num=$2
awk -F"[,:}]" '{for(i=1;i<=NF;i++){if($i~/'$KEY'\042/){print $(i+1)}}}' | tr -d '"' | sed -n ${num}p
DOMOTICZ=`curl -s --connect-timeout 2 --max-time 5 "http://192.168.0.10:8084/json.htm?type=devices&used=true&plan=7"`
if [ -z "$DOMOTICZ" ]
then
exit 1
WEG=$(echo $DOMOTICZ | jsonValue Status 1)
SLAPEN=$(echo $DOMOTICZ | jsonValue Status 2)
IMACSLAPEN=$(echo $DOMOTICZ | jsonValue Status 3)
if [[ -z "$WEG" || -z "$SLAPEN" || -z "$IMACSLAPEN" ]] ;
then
exit 1
fi
if [ $WEG == "On" ] || [ $SLAPEN == "On" ] || [ $IMACSLAPEN == "On" ]; then
/Applications/MyApps/imacsleep.command
fi
fi
The script grabs the sensors from roomplan 7 (so it only get the 3 switches instead of all used devices).
The litle jsonValue function decodes the json data and puts the status in variables.
Is one of the variables can't be set, the scripts exits.
If one of 3 statusses is 'On' a second script is called.
Posted: Friday 26 August 2016 12:37
by Robban
i can call a webpage to get the data from a sensor, but i want to extract the Data value in a sh script
cant find it anywhere
Posted: Monday 29 August 2016 11:22
by Robban
can“t figure out how to mask out a ex temperature data from a shell script.
lika i said i can call a website with the temperatue status, adress etc
Posted: Monday 29 August 2016 17:41
by Egregius
Maybe you should post your code? And explain better what you want?
Do you want to grab a temperature from a website and push it to domoticz? Or do you want to rab a temperature from Domoticz and use it in a shell script?
Posted: Tuesday 30 August 2016 9:43
by Robban
yes, i have voicerss working .
and i want a shell script that says ex " Godmorning, the outside temperature is xx degress.
the temperature is taken from a sensor inside the domoticz
Posted: Tuesday 30 August 2016 9:54
by Egregius
This should get you starting:
#!/bin/bash
KEY=$1
num=$2
DOMOTICZ=`curl -s --connect-timeout 2 --max-time 5 "http://192.168.0.10:8084/json.htm?type=devices&rid=278"`
then
exit 1
TEMP=$(echo $DOMOTICZ | jsonValue Temp 1)
echo $TEMP
fi
The variable $TEMP contains the temperature of thermometer with idx 278.
Value is for ex 20.40 so you should trim that a bit I guess.
Posted: Tuesday 30 August 2016 11:00
by Robban
THANKS ALOT!. worked fine
Posted: Tuesday 30 August 2016 13:52
by Robban
noticed that i got temperature like 18,80 , how do i get it to 18.8?
Posted: Tuesday 30 August 2016 14:47
by Egregius
Do you get 18 comma 80 or 18 point 80?
Wouldn't it be better to just remove the decimal and just say the whole degrees?
Then you could use something like this:
#!/bin/bash
KEY=$1
num=$2
then
exit 1
TEMPCLEAN=${TEMP%.*}
echo $TEMP $TEMPCLEAN
fi
Change TEMPCLEAN=${TEMP%.*} to TEMPCLEAN=${TEMP%,*} if comma is your decimal separator.
Posted: Tuesday 30 August 2016 15:44
by Robban
that did it! THANKS!
