Beginer use for solar monitoring (Solar Edge)
Posted: Wednesday 24 August 2016 0:06
Apologies if this is a 'noob' question but I was recommended Domoticz by a colleague and it seems good so far. I have a zwave dongle and logger for my supply meter on order but have I've got the install working on my Raspberry Pi.
I have a Solar Edge SE4000 inverter. I do currently use the solaredge monitoring webpage and although it's not great I would rather I could still use it in parallel with Domoticz at least initially.
I've found https://github.com/scns/SolarEdge-Domoticz which seems to do just that but I've also found http://www.domoticz.com/forum/viewtopic ... e&start=60 which suggests there are issues with this? I've just tried downloading it but get:
I'm sure there's some simple set up required I've not yet done!
Is it just me or does https://www.domoticz.com/wiki/SolarEdge suggest a seft up of the inverter comunicating directly to Domoticz and not to the the solaredge monitoring webpage does this mean that logging on both systems in parallel is no longer possible.
File "solar.py", line 5
<!DOCTYPE html>
SyntaxError: invalid syntaxIs it just me or does https://www.domoticz.com/wiki/SolarEdge suggest a seft up of the inverter comunicating directly to Domoticz and not to the the solaredge monitoring webpage does this mean that logging on both systems in parallel is no longer possible.
