Not all Nodes have been Queried yet, OpenZWave not fully initialized yet!
Posted: Monday 22 August 2016 21:42
by Evelen
Hello.
It started well for about a week ago, I noticed that the magnetic sensor in the door not registered, eventually I tried all my magnetic sensors in the house (4 pieces) and no registered anymore them flashed and have battery, but no command registered in Domoticz, checked log.
rebooted the server several times healed network, but the problem is the same. This is the only battery-powered devices I have (in use), but whether that's the problem I do not know.
Otherwise, I have various external powered units and these works all together fine.
UZB1 shows OpenZWave 1.4 to 235-gd9eb0ff and Domoticz is V3.5110
Magnetic sensors are central Vision ZD2102 AU
The Z-Wave tab also shows "Not all Nodes have been Queried yet, OpenZWave not fully initialized yet!", and it don't disaper
Any suggestions?
info:
Re: Not all Nodes have been Queried yet, OpenZWave not fully initialized yet!
Posted: Monday 22 August 2016 21:57
by Egregius
You should first check those dead nodes.
Posted: Monday 22 August 2016 22:11
by Evelen
Egregius wrote:You should first check those dead nodes.
Posted: Monday 22 August 2016 22:25
by Derik
Xheck your Zwcfg,xxxml file in the config map. [ winscp ]
Is this from you as user?
Or is this root?
Check all your batterys of your battery devices!!!!! [ not in Domoticz, with a battery tester ]
Or wakeup them!
En the reboot your pi. or ....
En place some log files
Posted: Monday 22 August 2016 22:37
by Evelen
Derik wrote:Xheck your Zwcfg,xxxml file in the config map. [ winscp ]
Or is this root?
Or wakeup them!
My zwcfg.xsd is like this:
- Spoiler: show
<?xml version='1.0'?>
<xs:schema
xmlns:xs='http://www.w3.org/2001/XMLSchema'
targetNamespace='http://code.google.com/p/open-zwave/'
xmlns:Driver='http://code.google.com/p/open-zwave/'
elementFormDefault='qualified'>
<xs:element name='Driver'>
<xs:complexType>
<xs:sequence>
<xs:element ref='Driver:Node' minOccurs='0' maxOccurs='unbounded'/>
</xs:sequence>
<xs:attribute name='version' type='xs:string' use='required'/>
<xs:attribute name='home_id' type='xs:string' use='required'/>
<xs:attribute name='node_id' type='xs:string' use='required'/>
<xs:attribute name='api_capabilities' type='xs:string' use='required'/>
<xs:attribute name='controller_capabilities' type='xs:string' use='required'/>
</xs:complexType>
</xs:element>
<xs:element name='Node'>
<xs:complexType>
<xs:sequence>
<xs:element ref='Driver:Manufacturer'/>
<xs:element ref='Driver:CommandClasses'/>
</xs:sequence>
<xs:attribute name='id' type='xs:string' use='required'/>
<xs:attribute name='name' type='xs:string' use='required'/>
<xs:attribute name='location' type='xs:string' use='optional'/>
<xs:attribute name='basic' type='xs:string' use='optional'/>
<xs:attribute name='generic' type='xs:string' use='optional'/>
<xs:attribute name='specific' type='xs:string' use='optional'/>
<xs:attribute name='type' type='xs:string' use='optional'/>
<xs:attribute name='listening' use='optional'>
<xs:simpleType>
<xs:restriction base='xs:string'>
<xs:enumeration value='true'/>
<xs:enumeration value='false'/>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
<xs:attribute name='frequentListening' use='optional'>
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
<xs:attribute name='beaming' use='optional'>
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
<xs:attribute name='routing' use='optional'>
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
<xs:attribute name='max_baud_rate' type='xs:string' use='optional'/>
<xs:attribute name='version' type='xs:string' use='optional'/>
<xs:attribute name='query_stage' type='xs:string' use='optional'/>
<xs:attribute name='security' use='optional'>
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
<xs:attribute name='nodeinfosupported' use='optional'>
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
</xs:complexType>
</xs:element>
<xs:element name='Manufacturer'>
<xs:complexType>
<xs:sequence>
<xs:element ref='Driver:Product'/>
</xs:sequence>
</xs:complexType>
</xs:element>
<xs:element name='Product'>
<xs:complexType>
<xs:attribute name='type' type='xs:string' use='required'/>
</xs:complexType>
</xs:element>
<xs:element name='CommandClasses'>
<xs:complexType>
<xs:sequence>
<xs:element ref='Driver:CommandClass' minOccurs='0' maxOccurs='unbounded'/>
</xs:sequence>
</xs:complexType>
</xs:element>
<xs:element name='CommandClass'>
<xs:complexType>
<xs:sequence>
<xs:element ref='Driver:Instance' minOccurs='0' maxOccurs='unbounded'/>
<xs:element ref='Driver:Value' minOccurs='0' maxOccurs='unbounded'/>
<xs:element ref='Driver:Associations' minOccurs='0' maxOccurs='unbounded'/>
</xs:sequence>
<xs:attribute name='after_mark' use='optional'>
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
<xs:attribute name='create_vars' use='optional'>
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
<xs:attribute name='getsupported' use='optional'>
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
<xs:attribute name='request_flags' type='xs:string' use='optional'/>
<xs:attribute name='base' type='xs:string' use='optional'/>
<xs:attribute name='override_precision' type='xs:string' use='optional'/>
</xs:complexType>
</xs:element>
<xs:element name='Instance'>
<xs:complexType>
<xs:attribute name='index' type='xs:string' use='required'/>
</xs:complexType>
</xs:element>
<xs:element name='Value'>
<xs:complexType>
<xs:sequence>
<xs:element ref='Driver:Help' minOccurs='0' maxOccurs='1'/>
<xs:element ref='Driver:Item' minOccurs='0' maxOccurs='unbounded'/>
</xs:sequence>
<xs:attribute name='genre' type='xs:string' use='required'/>
<xs:attribute name='instance' type='xs:string' use='required'/>
<xs:attribute name='label' type='xs:string' use='required'/>
<xs:attribute name='units' type='xs:string' use='required'/>
<xs:attribute name='read_only' use='required'>
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
<xs:attribute name='write_only' use='required'>
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
<xs:attribute name='verify_changes' use='required'>
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
<xs:attribute name='poll_intensity' type='xs:string' use='required'/>
<xs:attribute name='min' type='xs:string' use='required'/>
<xs:attribute name='max' type='xs:string' use='required'/>
<xs:attribute name='value' type='xs:string' use='optional'/>
<xs:attribute name='vindex' type='xs:string' use='optional'/>
<xs:attribute name='affects' type='xs:string' use='optional'/>
<xs:attribute name='size' type='xs:string' use='optional'/>
</xs:complexType>
</xs:element>
<xs:element name='Help'>
<xs:complexType mixed='true'>
</xs:complexType>
</xs:element>
<xs:element name='Item'>
<xs:complexType>
<xs:attribute name='value' type='xs:string' use='required'/>
</xs:complexType>
</xs:element>
<xs:element name='Associations'>
<xs:complexType>
<xs:sequence>
<xs:element ref='Driver:Group' minOccurs='0' maxOccurs='unbounded'/>
</xs:sequence>
<xs:attribute name='num_groups' type='xs:string' use='required'/>
</xs:complexType>
</xs:element>
<xs:element name='Group'>
<xs:complexType>
<xs:sequence>
<xs:element name='Node' minOccurs='0' maxOccurs='unbounded'>
<xs:complexType>
</xs:complexType>
</xs:element>
</xs:sequence>
<xs:attribute name='max_associations' type='xs:string' use='required'/>
<xs:attribute name='auto' use='required'>
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
</xs:complexType>
</xs:element>
</xs:schema>
Did not find any "xxxml" file
It is from my user, I don't have any battery tester, but should I try to change batteries? (Although it sounds unlikely that all are run out simultaneously, especially when the sensors lights.)
Also I don't have Pi, I have a VMWare ESXi Server and running Domoticz on Ubuntu Server.
Posted: Monday 22 August 2016 22:43
by Derik
some battery devices can kill your network when they are all most empty.
You also can try to stop domoticz
Remove the Zwcfg.xxx file and reboot..
and then check or the Zwcfg file is from u as user.
edit:
This is my file:
<?xml version="1.0" encoding="utf-8" ?>
<Driver xmlns="http://code.google.com/p/open-zwave/" version="3" home_id="0xca9c1e7b" node_id="1" api_capabilities="0" controller_capabilities="8" poll_interval="50000" poll_interval_between="false">
<Node id="1" name="" location="" basic="2" generic="2" specific="1" type="Static PC Controller" listening="true" frequentListening="false" beaming="true" routing="false" max_baud_rate="40000" version="4" query_stage="Complete">
<Manufacturer id="86" name="Aeotec">
<Product type="1" id="5a" name="Z-Stick Gen5" />
</Manufacturer>
<CommandClasses>
<CommandClass id="32" name="COMMAND_CLASS_BASIC" version="1" after_mark="true">
<Instance index="1" />
<Value type="byte" genre="basic" instance="1" index="0" label="Basic" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
</CommandClass>
</CommandClasses>
</Node>
<Node id="3" name="Garage" location="" basic="4" generic="16" specific="1" type="Binary Power Switch" listening="true" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="3" query_stage="Complete">
<Manufacturer id="159" name="Qubino">
<Product type="2" id="1" name="ZMNHBA2 Flush 2 Relays" />
</Manufacturer>
<CommandClasses>
<CommandClass id="37" name="COMMAND_CLASS_SWITCH_BINARY" version="1" request_flags="5" innif="true">
<Instance index="1" endpoint="1" />
<Instance index="2" endpoint="2" />
<Value type="bool" genre="user" instance="1" index="0" label="Switch" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
<Value type="bool" genre="user" instance="2" index="0" label="Switch" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
</CommandClass>
<CommandClass id="39" name="COMMAND_CLASS_SWITCH_ALL" version="1" request_flags="5" innif="true">
<Value type="list" genre="system" instance="1" index="0" label="Switch All" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
<Item label="Disabled" value="0" />
<Item label="Off Enabled" value="1" />
<Item label="On Enabled" value="2" />
<Item label="On and Off Enabled" value="255" />
</Value>
</CommandClass>
<CommandClass id="49" name="COMMAND_CLASS_SENSOR_MULTILEVEL" version="3" request_flags="1" innif="true">
<Value type="decimal" genre="user" instance="1" index="1" label="Temperature" units="C" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="-999.9" />
</CommandClass>
<CommandClass id="50" name="COMMAND_CLASS_METER" version="3" request_flags="3" innif="true">
<Value type="decimal" genre="user" instance="1" index="0" label="Unknown" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="87.9" />
<Value type="decimal" genre="user" instance="2" index="0" label="Unknown" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="140.6" />
</CommandClass>
<CommandClass id="96" name="COMMAND_CLASS_MULTI_INSTANCE/CHANNEL" version="2" request_flags="1" innif="true" mapping="endpoints">
</CommandClass>
<CommandClass id="112" name="COMMAND_CLASS_CONFIGURATION" version="1" request_flags="5" innif="true">
<Value type="list" genre="config" instance="1" index="1" label="Input 1 switch type" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="1" vindex="1" size="1">
<Item label="Mono-stable switch type (push button)" value="0" />
<Item label="Bi-stable switch type" value="1" />
So i think you got the wrong
- ScreenShot215.jpg (54.83 KiB) Viewed 3008 times
Posted: Wednesday 24 August 2016 20:58
by Evelen
oh.
I did took the file from "open-zwave-read-only/config"
my file from "domoticz/config" was "zwcfg_0xd3cf129c.xml": (tryed to delete this)
- Spoiler: show
<?xml version="1.0" encoding="UTF-8"?>
-<Driver poll_interval_between="false" poll_interval="60000" controller_capabilities="8" api_capabilities="0" node_id="1" home_id="0xd3cf129c" version="3" xmlns="http://code.google.com/p/open-zwave/">
-<Node version="4" query_stage="Complete" max_baud_rate="40000" routing="true" beaming="true" frequentListening="false" listening="true" type="Static PC Controller" specific="1" generic="2" basic="2" location="" name="" id="1">
-<Manufacturer name="Vision" id="109">
<Product type="1001" name="ZU1401 Z-Wave USB Stick" id="105"/>
</Manufacturer>
-<CommandClasses>
-<CommandClass version="1" name="COMMAND_CLASS_BASIC" id="32" after_mark="true">
<Instance index="1"/>
<Value type="byte" index="0" value="0" max="255" min="0" poll_intensity="0" verify_changes="false" write_only="false" read_only="false" units="" label="Basic" instance="1" genre="basic"/>
</CommandClass>
</CommandClasses>
</Node>
-<Node version="4" query_stage="Complete" max_baud_rate="40000" routing="true" beaming="true" frequentListening="false" listening="true" type="Multilevel Power Switch" specific="1" generic="17" basic="4" location="" name="Zipato" id="13" nodetype="0" devicetype="1536" roletype="5">
-<Manufacturer name="Zipato" id="131">
<Product type="2" name="RGBW LED Bulb" id="2"/>
</Manufacturer>
-<CommandClasses>
-<CommandClass version="2" name="COMMAND_CLASS_SWITCH_MULTILEVEL" id="38" innif="true">
<Value type="byte" index="0" value="0" max="255" min="0" poll_intensity="0" verify_changes="false" write_only="false" read_only="false" units="" label="Level" instance="1" genre="user"/>
<Value type="button" index="1" max="0" min="0" poll_intensity="0" verify_changes="false" write_only="true" read_only="false" units="" label="Bright" instance="1" genre="user"/>
<Value type="button" index="2" max="0" min="0" poll_intensity="0" verify_changes="false" write_only="true" read_only="false" units="" label="Dim" instance="1" genre="user"/>
<Value type="bool" index="3" value="True" max="0" min="0" poll_intensity="0" verify_changes="false" write_only="false" read_only="false" units="" label="Ignore Start Level" instance="1" genre="system"/>
<Value type="byte" index="4" value="0" max="255" min="0" poll_intensity="0" verify_changes="false" write_only="false" read_only="false" units="" label="Start Level" instance="1" genre="system"/>
</CommandClass>
-<CommandClass version="1" name="COMMAND_CLASS_COLOR" id="51" innif="true" colorchannels="31" request_flags="2">
<Value type="string" index="0" value="#FF90000000" max="0" min="0" poll_intensity="0" verify_changes="false" write_only="false" read_only="false" units="#RRGGBBWWCW" label="Color" instance="1" genre="user"/>
-<Value type="list" index="1" max="0" min="0" poll_intensity="0" verify_changes="false" write_only="false" read_only="false" units="" label="Color Index" instance="1" genre="user" size="18" vindex="17">
<Item value="0" label="Off"/>
<Item value="1" label="Cool White"/>
<Item value="2" label="Warm White"/>
<Item value="3" label="Red"/>
<Item value="4" label="Lime"/>
<Item value="5" label="Blue"/>
<Item value="6" label="Yellow"/>
<Item value="7" label="Cyan"/>
<Item value="8" label="Magenta"/>
<Item value="9" label="Silver"/>
<Item value="10" label="Gray"/>
<Item value="11" label="Maroon"/>
<Item value="12" label="Olive"/>
<Item value="13" label="Green"/>
<Item value="14" label="Purple"/>
<Item value="15" label="Teal"/>
<Item value="16" label="Navy"/>
<Item value="17" label="Custom"/>
</Value>
<Value type="int" index="2" value="31" max="2147483647" min="-2147483648" poll_intensity="0" verify_changes="false" write_only="false" read_only="false" units="" label="Color Channels" instance="1" genre="system"/>
</CommandClass>
-<CommandClass version="1" name="COMMAND_CLASS_DEVICE_RESET_LOCALLY" id="90" innif="true" request_flags="4">
</CommandClass>
-<CommandClass version="1" name="COMMAND_CLASS_ZWAVE_PLUS_INFO" id="94" innif="true" request_flags="4">
<Value type="byte" index="0" value="1" max="255" min="0" poll_intensity="0" verify_changes="false" write_only="false" read_only="true" units="" label="ZWave+ Version" instance="1" genre="system"/>
<Value type="short" index="1" value="1536" max="32767" min="-32768" poll_intensity="0" verify_changes="false" write_only="false" read_only="true" units="" label="InstallerIcon" instance="1" genre="system"/>
<Value type="short" index="2" value="1536" max="32767" min="-32768" poll_intensity="0" verify_changes="false" write_only="false" read_only="true" units="" label="UserIcon" instance="1" genre="system"/>
</CommandClass>
-<CommandClass version="1" name="COMMAND_CLASS_CONFIGURATION" id="112" innif="true" request_flags="4">
-<Value type="byte" index="1" value="50" max="100" min="0" poll_intensity="0" verify_changes="false" write_only="false" read_only="false" units="" label="RGB Color" instance="1" genre="config">
<Help>Color Temperature</Help>
</Value>
-<Value type="byte" index="2" value="10" max="32" min="0" poll_intensity="0" verify_changes="false" write_only="false" read_only="false" units="" label="Shock Sensor" instance="1" genre="config">
<Help>Shock sensor : 0=Maximum sensitivity ; 32=minimum sensitivity</Help>
</Value>
</CommandClass>
-<CommandClass version="1" name="COMMAND_CLASS_MANUFACTURER_SPECIFIC" id="114" innif="true" request_flags="4">
</CommandClass>
-<CommandClass version="1" name="COMMAND_CLASS_POWERLEVEL" id="115" innif="true" request_flags="4">
-<Value type="list" index="0" max="0" min="0" poll_intensity="0" verify_changes="false" write_only="false" read_only="false" units="dB" label="Powerlevel" instance="1" genre="system" size="1" vindex="0">
<Item value="0" label="Normal"/>
<Item value="1" label="-1dB"/>
<Item value="2" label="-2dB"/>
<Item value="3" label="-3dB"/>
<Item value="4" label="-4dB"/>
<Item value="5" label="-5dB"/>
<Item value="6" label="-6dB"/>
<Item value="7" label="-7dB"/>
<Item value="8" label="-8dB"/>
<Item value="9" label="-9dB"/>
</Value>
<Value type="byte" index="1" value="0" max="255" min="0" poll_intensity="0" verify_changes="false" write_only="false" read_only="false" units="seconds" label="Timeout" instance="1" genre="system"/>
<Value type="button" index="2" max="0" min="0" poll_intensity="0" verify_changes="false" write_only="true" read_only="false" units="" label="Set Powerlevel" instance="1" genre="system"/>
<Value type="byte" index="3" value="0" max="255" min="0" poll_intensity="0" verify_changes="false" write_only="false" read_only="false" units="" label="Test Node" instance="1" genre="system"/>
-<Value type="list" index="4" max="0" min="0" poll_intensity="0" verify_changes="false" write_only="false" read_only="false" units="dB" label="Test Powerlevel" instance="1" genre="system" size="1" vindex="0">
</Value>
<Value type="short" index="5" value="0" max="32767" min="-32768" poll_intensity="0" verify_changes="false" write_only="false" read_only="false" units="" label="Frame Count" instance="1" genre="system"/>
<Value type="button" index="6" max="0" min="0" poll_intensity="0" verify_changes="false" write_only="true" read_only="false" units="" label="Test" instance="1" genre="system"/>
<Value type="button" index="7" max="0" min="0" poll_intensity="0" verify_changes="false" write_only="true" read_only="false" units="" label="Report" instance="1" genre="system"/>
-<Value type="list" index="8" max="0" min="0" poll_intensity="0" verify_changes="false" write_only="false" read_only="true" units="" label="Test Status" instance="1" genre="system" size="1" vindex="0">
<Item value="0" label="Failed"/>
<Item value="1" label="Success"/>
<Item value="2" label="In Progress"/>
</Value>
<Value type="short" index="9" value="0" max="32767" min="-32768" poll_intensity="0" verify_changes="false" write_only="false" read_only="true" units="" label="Acked Frames" instance="1" genre="system"/>
</CommandClass>
-<CommandClass version="1" name="COMMAND_CLASS_ASSOCIATION" id="133" innif="true" request_flags="4">
-<Associations num_groups="1">
-<Group index="1" label="Report" auto="true" max_associations="5">
<Node id="1"/>
</Group>
</Associations>
</CommandClass>
-<CommandClass version="1" name="COMMAND_CLASS_VERSION" id="134" innif="true" request_flags="4">
<Value type="string" index="0" value="3" max="0" min="0" poll_intensity="0" verify_changes="false" write_only="false" read_only="true" units="" label="Library Version" instance="1" genre="system"/>
<Value type="string" index="1" value="3.92" max="0" min="0" poll_intensity="0" verify_changes="false" write_only="false" read_only="true" units="" label="Protocol Version" instance="1" genre="system"/>
<Value type="string" index="2" value="1.06" max="0" min="0" poll_intensity="0" verify_changes="false" write_only="false" read_only="true" units="" label="Application Version" instance="1" genre="system"/>
</CommandClass>
</CommandClasses>
</Node>
</Driver>
It is also a file called "zwcfg_0xf3eab290.xml" from root (don't jave access to read og replace this)
Posted: Wednesday 24 August 2016 21:01
by Derik
try to delete them
Stp first domoticz
Then delete
Then update/upgrade
reboot
check if files are user and not root..
Posted: Wednesday 24 August 2016 21:17
by Evelen
i found and downloaded zwcfg_0xd3cf129c.xml from hardawre tab in Z-wave @ domoticz (download config):
also, rebooted server (vm), then stoped domotics.sh service
now I deleted the file (renamed) and I head access to do it.
started service, domoticz.sh.
now it worked
