RaZberry Hardware reboot, nothing works
Posted: Sunday 21 August 2016 20:19
by SilverShaded
For sme unknown reason i decided to do a hardware reboot of the RaZberry. Now i can not detect any Z-ave devices. The red LED lights up when its waiting for a signal but pressing buttons on the various z-wave devices does nothing. Any suggestions?
Re: RaZberry Hardware reboot, nothing works
Posted: Sunday 21 August 2016 20:27
by trixwood
I would guess the serial port changed name, did you check i the hardware tab if it still filled in?
Serial port box is empty instead ttyXX?
example pic (ignore the add button):
http://www.vesternet.com/media/wysiwyg/ ... tion_3.png
Posted: Sunday 21 August 2016 22:42
by SilverShaded
HI, yes i theserial port is filled in. If i click on setup, it has the Razberry controller as the only device present. I tried to include nodes but nothing seems to register. I also tried resetting the TKBHOme wall plus to its factory settings (three clicks then one long click?) but that didnt seem to help. Is there any way i can check if the signals are being recieved by the Razberry?
Posted: Sunday 21 August 2016 22:59
by trixwood
Did you try resetting the controller (soft reset, or hard reset)?
Screen Shot 2016-08-21 at 22.58.36.png (82.55 KiB) Viewed 2453 times
And check the control panel...
Posted: Sunday 21 August 2016 23:28
by SilverShaded
Hi, yes it was the hardware reset which seemd to cause my problem in the first place. Yesterday all but one of the nodes was wroking properly, i did did a hardware reset to see if that would help and since then none of the nodes show up or will re-include.
the green light on razberry does not light at all.
in the control panel i cant see any information, i mean it just says one node, and no other usefull information regardless of what i try and get it to do.
Posted: Monday 22 August 2016 0:21
by trixwood
I would check there support, i have no idea.
http://razberry.z-wave.me/index.php?id=29
Posted: Tuesday 23 August 2016 17:33
by wizzard72
Have you tried to shutdown domoticz, remove the razberry card (disconnect power first), start domoticz, shutdown domoticz, add the razberry card and start domoticz again. That solved my problems when razberry doesn't work any more
Verstuurd vanaf mijn SM-T700 met Tapatalk
