Ethernet to RS232
Cletus
Domoticz version: Latest
Ethernet to RS232
Post by Cletus »
Could not find a real answer so trying here :)
I would like to control my AV receiver and TV via Domoticz, they both have the capability to be controlled via RS232, but my Domoticz appliance is in another place than the TV and receiver.
Does anyone know if there is an Ethernet to RS232 controller and if so can i connect this to the TV and AV receiver via Domoticz so that i can control my TV and Receiver with it? (Or and old Rpi with USB to Serial cables in between)
Any help would be greatly appreciated!
Thanks! Paul
This is our world now... the world of the electron and the switch, the beauty of the baud.
trixwood
Re: Ethernet to RS232
Post by trixwood »
https://www.openxtra.co.uk/p/netport-ii ... dapter-dce
or build one yourself with an arduino/esp and ethernet shield and something like this
http://www.aliexpress.com/item/Free-shi ... 95985.html
Marci
Domoticz version: 3.8153
Post by Marci »
Raspberry Pi, USB to RS232 adapter, Node-Red, Tcp in node to serial out node and vice versa. Done.
Domosapiens
Domoticz version: V3.5981
Post by Domosapiens »
Something like this ?
http://nl.aliexpress.com/item/1pc-USR-T ... .52.oALqOd
bizziebis
Domoticz version: 3.8805
Post by bizziebis »
@Domosapiens
That will only work in conjunction with a MAX232A. RS232 levels can be as high as 15V so a TTL device won't like it very much ;)
I'm building one myself with these parts:
http://s.aliexpress.com/FN7zQneI
Http://s.aliexpress.com/Qf2qeIra
