FIbaro FGS double switch problems
jorgitold
Domoticz version: 3.5839
Post by jorgitold »
It is normal this error message . ( See attachment )
I can activate the device from the switch and with a url api / json but when I try from blocky not work
Only swicth conected
Raspberry PI 3, Domoticz 4834 , Controller: AEOTEC Z-Stick Gen5 usb, Devices: Fibaro FGS-222
Egregius
Domoticz version: v2024.7
Re: FIbaro FGS double switch problems
Post by Egregius »
All my devices that have the test status field are indicated as failed, so I wouldn't mind about it much.
Probably something wrong in your blockly but I don't know anything about that.
StanHD
Post by StanHD »
Hi, you have used the wrong Control Block. If you do not have an "else If" then you should use the block without the Blue "+"
Then it should work :)
Python:- Broadlink RM2, Sonos
jorgitold
Post by jorgitold »
my configuratio is:
nodes
FIbaro device configuration
fibaro configuration.JPG (164.87 KiB) Viewed 1695 times
Only I just want to turn Fibaro double switch from blocky
my blocky :
IF true
do set switch LUZ_ENTRADA = ON
I feel should be very easy but it does not work
thanks
Egregius
Post by Egregius »
Have you tried the reply from StanHD?
Now you use a if/else block without an else. If only one if is nescessary you must use a simple if block.
jorgitold
Post by jorgitold »
It works right now , a beginner's mistake . thank you very much
