[SUGGESTION] Barometric pressure formats
Posted: Thursday 18 August 2016 11:17
Hi all!
I was not able to access the tracker.php - Is it down?
Summary:
Could additional barometric pressure formats be implemented. - (Especially mBAR format?)
https://en.wikipedia.org/wiki/Pascal_(u ... ibar_units
Reason (story):
I'm updating my barometric pressure for a TEMP;HUM;HUM_STAT;BAR;BAR_FOR sensor.
I'we been pushing the values over JSON from node-red with:
http://192.168.XX.XX:8080/json.htm?type ... meter}}};0
It works, and Domoticz receives the values.
But it seems like Domoticz only measures barometric pressure in hPA and an option for mBAR is not available.
Expected outcome:
1. Choose one general pressure format to be applied for all barometric pressure sensors in Setups > Settings > Meters/Counters
2. For every barometric pressure: Edit > Choose sensor reporting Value. - Reporting value is then re-calculated to the pre-chosen format in step 1.
Summary:
Reason (story):
Expected outcome:
