Multi zone temperature control
Posted: Wednesday 17 August 2016 0:55
I'm new to domoticz. I got solar panels last month and used a raspberry with domoticz installed to get the data from the smart meter. The data from the solarpanels itself (solaredge 3500) still not working. But that's for later
Using domoticz and reading i "discovered" that multizone temperature control was possible.
The kids rooms are to cold in the winter but the cv is not turning on because the controlled room is at setpoint. So this has priority.
As far as i can tell i need the following items.
Every room a thermostat:
The secure srt321 was adviced. But they could tell me if if it was possible to get the actual room temperature from it.
Or is it better to take the danfoss....
Boilerswitch:
Secure boiler switch. Just a switch to start the boiler/cv
Every radiator a thermostatic valve:
The danfoss lc13 was adviced.
These items can operate stand alone without domoticz. Every thermostate should be a trigger to start the boilerswitch.
But with domoticz i would be able to set temperatures from an app and get reading. This to check/controll kids room temps and adjust.
For the domotics part i need a zwave rflink controller on 868 mhz (if im correct)
Has anyone some more info about this subject. This wil be an expensive project and would like to get it right the first time. So before buying i need more info
Verstuurd vanaf mijn SM-G920F met Tapatalk
Boilerswitch:
