Make Sub/Slave/Unused devices accessable in scripts
Posted: Monday 15 August 2016 1:45
Hello I posted my question on Monday 04 July 2016
The Question was: I'm trying to get the state of a Sub/Slave device in a lua script, but it seems that Sub/Slave devices can't be accessed?
am I doing something wrong ?
Regards,
Frank
So no replies where in order, and I am (still) not able to use the Sub/Slave/Unused devices in a script, so hereby I want to make the suggestion to make all devices used/unused/sub and slaves accessible in scripts..
Why?
The SI1145 Sensor returns 3 values: UV, Visible, IR (luminosity)
The UV value is no problem, in combination with MySensors Domoticz can 'recognize' the sensor and act accordingly.
The Visible and IR values have no suffix, the are a 'counted' value (0...65535).
And because Domoticz cant handle the MySensors S_CUSTOM and V_VALX values. I was searching for a alternative.
So I made a S_INFO with V_TEXT sensor. But this is a list only with values, no historic graph can be made.
With DUMMY Sensor created a Custom Sensor and with a lua script I copy the V_TEXT value In the Custom Sensor Value.
But, The Info sensor has to be 'in use' and shows up on the utility tab, next to the Custom Sensor
. The Info Sensor is , in this case, a helper and should not be visible. But doing a set_unset Info Sensor makes the 'device' invisible for the scripts.
Frank
Regards,
Frank
Why?
Frank
