Greenwave 6ports
Posted: Sunday 14 August 2016 10:08
by Varazir
I have a strange problem with my zwave greenwave 6 port switch.
At 4am every day Domoticz stops updating / seeing it.
Hardware: Raspberry Pi 1, Razberry board
Domoticz: Beta 3.5478
I have tried with restarting the raspberry pi but it didn't do any affect, still stopped at a 4 am.
Solution has been to heal network or enable polling on the node.
Or restart domoticz / raspberry pi.
I can still switch on the portsand one port is always on "RouterCC"
TIA
Daniel
Re: Greenwave 6ports
Posted: Sunday 14 August 2016 11:56
by gizmocuz
You must enable polling on the greenwave's....
Re: RE: Re: Greenwave 6ports
Posted: Sunday 14 August 2016 11:58
by Varazir
gizmocuz wrote:You must enable polling on the greenwave's....
But that get reseted everyday.
Skickat från min Nexus 5 via Tapatalk
Posted: Tuesday 16 August 2016 12:10
by Varazir
Found this
2016-08-16 04:00:01.908 OpenZWave: Node Removed. HomeID: 3260666225, NodeID: 1 (0x01)
2016-08-16 04:00:07.548 Ending automatic database backup procedure...
2016-08-16 04:00:07.669 OpenZWave: New Node added. HomeID: 3260666225, NodeID: 1 (0x01)
2016-08-16 04:00:10.686 OpenZWave: Node Removed. HomeID: 3260666225, NodeID: 2 (0x02)
2016-08-16 04:00:10.757 OpenZWave: New Node added. HomeID: 3260666225, NodeID: 2 (0x02)
2016-08-16 04:00:11.580 OpenZWave: Node Removed. HomeID: 3260666225, NodeID: 6 (0x06)
2016-08-16 04:00:11.619 OpenZWave: New Node added. HomeID: 3260666225, NodeID: 6 (0x06)
2016-08-16 04:00:12.629 OpenZWave: Node Removed. HomeID: 3260666225, NodeID: 8 (0x08)
2016-08-16 04:00:12.641 OpenZWave: New Node added. HomeID: 3260666225, NodeID: 8 (0x08)
2016-08-16 04:00:13.655 OpenZWave: Unhandled class: 0x87 (INDICATOR), NodeID: 2 (0x02), Index: 0, Instance: 1
2016-08-16 04:00:13.705 OpenZWave: Unhandled class: 0x87 (INDICATOR), NodeID: 6 (0x06), Index: 0, Instance: 1
Posted: Saturday 20 August 2016 9:52
by mischa
Varazir wrote: I have a strange problem with my zwave greenwave 6 port switch.
l
Could the automatics healing of the network aroun 4 am coursing your problem?
Posted: Saturday 20 August 2016 10:01
by Egregius
Disable it and see ;)
Posted: Saturday 20 August 2016 10:22
by Varazir
Egregius wrote:Disable it and see ;)
That was to easy... I'll report back tomorrow
Posted: Saturday 20 August 2016 11:16
by Egregius
I also see you have automatic database backup enabled? Do you have a large database? I've seen topics before where there were issues with that.
I would disbale that also for now. Run couple of days, and then enable one by one and verify.
Posted: Saturday 20 August 2016 11:25
by Varazir
Egregius wrote:I also see you have automatic database backup enabled? Do you have a large database? I've seen topics before where there were issues with that.
Ok, I'll do that. There should be a setting to the autobackup, 1h 12h 1d 7d
Posted: Saturday 20 August 2016 12:03
by Egregius
Just make a copy of your domoticz folder to a nas or ftp server. Preferably with some versioning.
