Connecting old Kaku plugs
Goldwing1973
Domoticz version: Stable
Post by Goldwing1973 »
i still have some older KaKu plugs (with a channel selector wheel on the back) lying around.
Is it possible to connect these to Domoticz?
I tried the "Manual Light Switch" in the switches page and figured that each ID field corresponds with the A B C D on the wheel on the back of the KaKu, but i can't get them to work.
Over 50 Z-Wave Devices (Fibaro and Neo), 4xLogitech Hub, 2xPhilips Hue Bridge+55 Lights, 1x Nest Thermostat, 2xNetatmo Weather Station, 1xSkybell v1 Doorbell, 3 Kwikset KEVO Doorlocks and Domoticz running on a Intel NUC
Goldwing1973
Re: Connecting old Kaku plugs
Never mind, I got them to work.
I tried connecting the older KaKu's the same way i connected the newer ones, using the AC Type.
When i changed the AC Type to ARC i could select the A,B,C or D and the 1,2 or 3 Setting.
Derik
Post by Derik »
good luck...
manjh
Domoticz version: 2025.2
Post by manjh »
Goldwing1973 wrote:Never mind, I got them to work.
I believe the old "home group" letter will go all the way from A through P.
Within each home group you can use device numbers 1 through 16, although I found there is a bug somewhere when using address 16. Not sure if it is in Domoticz or RFLink, but I've steered clear of 16...
Hans
