OWL and Wind Meter Script
Posted: Wednesday 10 August 2016 19:18
Hi to everyone
I am a newbie on Domoticz and starting to using it i found some issue and i want to share my small experience, on the past few weeks i tried to implement both OWL energy meter and Lacrosse weather station discovering some discrepancies, to solve those issue i wrote two small LUA scripts using, as a baseline, some code from this forum.
OWL scripts, very simple, to adjust the readings according with the real line voltage, if you need to use it you have only to edit the device name and the new device ID, please remember to create the new virtual device (deviceid) and to edit the name of the real device (Owl on the script, Owl CM119 IT is the virtual device name )
Wind script, to take care on some wrong reading on Gust Speed (stuck on 16.4 m/s) and to extract the wind chill,
I hope this will be helpful
Best
Francesco
function update(device, id, power, energy, index)
commandArray[index] = {['UpdateDevice'] = id .. "|0|" .. power .. ";" .. energy}
local voltage = 220
local owlvoltage = 230
local deviceid = 5
if devicechanged['Owl'] then
owl = otherdevices_svalues['Owl']
print('Owl : '..owl)
words = {}
for w in string.gmatch(owl, "%d+%.?%d*") do
words[#words + 1] = w
voltage = voltage / owlvoltage
power = voltage * tonumber(words[1])
energy = voltage * tonumber(words[2])
housepower = math.floor( (power * 10^1) + 0.5) / (10^1)
print('Owl CM119 IT : '..housepower)
commandArray['Owl Switch'] = 'On'
update("Owl CM119 IT", deviceid, power, energy, 1)
function update(device, id, direction, heading, speed, gust, temp, chill, index)
commandArray[index] = {['UpdateDevice'] = id .. "|0|" .. direction .. ";" .. heading .. ";" .. speed .. ";" .. gust .. ";" .. temp .. ";" .. chill}
local deviceid = 68
if devicechanged['LaCrosseV2 Wind Meter'] then
wind = otherdevices_svalues['LaCrosseV2 Wind Meter']
temp = otherdevices_svalues['LaCrosseV2 Esterno']
print('LaCrosseV2 Wind Meter : '..wind)
print('LaCrosseV2 Esterno : '..temp)
words = {}
for w in string.gmatch(wind, "%d+%.?%d*") do
word = {}
for w in string.gmatch(wind, "%w+") do
word[#word + 1] = w
wordt = {}
for w in string.gmatch(temp, "%d+%.?%d*") do
wordt[#wordt + 1] = w
direction = tonumber(words[1])
heading = (word[3])
speed = tonumber(words[2])
gust = tonumber(words[3])
temp = tonumber(wordt[1])
chill = tonumber(words[5])
speedwc = speed * 3.6
speedwcexp = speedwc^0.16
if temp < 10.0 and speedwc > 4.8 then
chill = 13.12 + (0.6215 * temp) - (11.37 * speedwcexp) + (0.3965 * temp * speedwcexp)
chill = temp
chill = math.floor( (chill * 10^1) + 0.5) / (10^1)
print ('temp : '..temp)
print ('chill : '..chill)
if gust == 164 then
gust = speed
gust = gust
commandArray['Wind switch'] = 'On'
update("Wind", deviceid, direction, heading, speed, gust , temp , chill ,1)
Best
Francesco
