New user - help getting started
Posted: Tuesday 09 August 2016 23:08
I need to replace my Ninja Block as I fear the cloud service will disappear soon, so after a period of research, I got Domoticz running on a Raspberry Pi I had kicking around and ordered an Arduino/RFlink/Antenna/Enclosure kit from Nodo shop.
Having soldered the kit, plugged into the Arduino and assembled into the case, I decided to flash the latest firmware. Downloaded, upzipped to my Google cloud drive and tried to run RFLinkLoader, but on COM1 and COM3 (only two options), got "Programming Failed" error. Tried on several USB ports - same error. Realised I should have installed Arduino drivers, so did so, rebooted computer and tried again but same result.
Tried plugging Arduino/RFlink into RPi USB port then in Domoticz, installed the RFLink via Setup, Hardware, add (now have two RFLink USB, one on /dev/ttyAMA0 and one on /dev/ttyACM00. Get green power light on Arduino and occassional TX and AREF LED flashes along with an unidentified solid amber LED on the RFLink, but doesn't seem to pick up any RF signals I initiate.
I know I've either missed a fundamental step, misunderstood what I'm meant to be doing or have done something dumb - but I'm stuck. Any suggestions?
(Posted in the right forum now - inadvertantly posted in the RFXcom forum first. Great start for a first post! - It's been a long day ...)
