SEAV Implementation
Posted: Tuesday 09 August 2016 22:40
by Goldwing1973
Request,
Could you please add the SEAV TXS2 control?
I have three sunscreens with remote control that use that system.
Bert Weijenberg mailed me that RFXcom firmware 1006 has support for it.
Thanks in advance.
Re: SEAV Implementation
Posted: Sunday 14 August 2016 20:54
by b_weijenberg
TXS4 is supported by the RFXtrx433E but unknown if TXS2 is supported!
Posted: Tuesday 16 August 2016 14:55
by Goldwing1973
b_weijenberg wrote:TXS4 is supported by the RFXtrx433E but unknown if TXS2 is supported!
Can i keep a log or something when i push the button on the remote control so you can compare the TXS4 with the control codes send by the TXS2?
I also have a TXS3 and a TXS1 lying around somewhere if needed
Or is there another way to test it?
Posted: Tuesday 16 August 2016 15:39
by b_weijenberg
Please contact support rfxcom.com for implementation of other SEAV remotes.
Posted: Wednesday 17 August 2016 23:10
by Goldwing1973
b_weijenberg wrote:Please contact support rfxcom.com for implementation of other SEAV remotes.
I just remembered this, the RFXcom already is capable of sending the correct signal for a TXS2 remote control.
I've tested this myself with RFXmngr 18.0.0.7, i even mailed you that it worked on 7-8-2016 at 00:07.
I'ts just that it doesn't work *yet* in Domoticz, it has to be added to Domoticz.
