Suggestion: Frontend code refactoring / improvements
sjoerdmulder
Post by sjoerdmulder »
I tried to work with the Domoticz front-end code and it seems that:
- Modularization is not really applied (comparing with the backend code), e.g. the HardwareController.js contains 5000+ LOC and the configuration of almost every device.
- Lots of global javascript variables are used that might possible conflict.
- No separation of model, view and controller. Making skinning etc difficult, e.g. a lot of HTML is just being assigned an ID and that is mention then everwhere in the javascript.
But there are not only `bad-parts`. I think its great that it is using AngularJS + Router to separate the different views! So why stop there. Maybe we could write-up some examples and rewrite some parts so they use AngularJS more, this gives great possibilities to extend Domoticz web-ui without adding more global variables and mixing of HTML, CSS and Javascript together.
As example i worked a bit on the ZWave Hardware component (WIP!!! the User codes are not yet working since i don't have a security device):
https://github.com/sjoerdmulder/domotic ... fb5376df39
Changes applied are:
- Move all ZWave specific javascript and html in a app/hardware/ZWave.js and views/hardware/zwave.html files (so HardwareController and hardware.html are clean and only managing the "Hardware" page)
- Adding a /Hardware/ZWave/:name/:idx url so parameters are passed in through the URL making refreshing a page work and not ending up at the /Hardware page again.
- Using angular's $scope so that the function are only available for the Zwave component and not globally floating around.
- Using angular's ng-model for two-way binding, so whenever the input is updated the variable in javascript is also updated (e.g. $scope.current.Name) and vice-versa (e.g. setting $scope.current.Name will automaticly set the value to the input-field).
What do you guys think? I think it would be great too move in this direction to have a Domoticz that is more future-proof and better maintainable. We could start by when new devices are added requiring them to follow this pattern. (e.g. using the Router and separate Javascript and HTML files)
gizmocuz
Re: Suggestion: Frontend code refactoring / improvements
Post by gizmocuz »
Looking gooood !
The reason was that i added angularjs after more then one year of development...
Now with all knowledge, this should indeed have been made like the way you propose !
If you would like to optimize this, that would be great !
One other idea... is it (somehow), possible to keep the configuration/setup part inside the corresponding hardware c++ file ?
Like a "const char *" with the code ?
The reason for this, is that we can keep all hardware related stuff together.... if not, i like your way of course
