Qubino ZMNHDD1 Flush Dimmer cant get I2 and I3 working
Posted: Thursday 04 August 2016 10:00
by leby
I have installed a few new nodes in a room where I intended to use I2 and I3 on a Qubino ZMNHDD1 Flush Dimmer to control a couple of scenarios.
In the room I have:
a) One Qubino ZMNHDD1 Flush Dimmer, this one I use for a ceiling lamp and is located at the switch
b) Three Qubino Flush Dimmer 0-10V, this three are located in the led cups in the ceiling and they anyway don't have more than one switch available.
(I run on WIN10 with Aeon Labs Z-stick gen5)
The plan was to with I2 turn on all 0-10V dimmers to a predefined dim level, I3 should turn off all lights and turn on the lights on the outside of the house.
Well now I can't get I2 or I3 to work, I think I can see them in the device list but not possible to activate / deactivate not with the switch or with domoticz.
Its node 37 below that is the Flush Dimmer with I2 & I3, the 0-10V dimmer is shown as "Qubino Unknown: type=0001, id=0053" but works as expected.
Filtering the devise list on 000025 that should be the node where I have problem I get this list
As you can see I get 6 lines with switches but only "00002501 1 Taklampa källarelägenhet Light/Switch Switch" works and that is of course the switch connected to I1.
If I click any else of the type "Light/Switch" I get
Any kind person that can help?
Best Regards Lennart
Re: Qubino ZMNHDD1 Flush Dimmer cant get I2 and I3 working
Posted: Thursday 11 August 2016 10:11
by bbqkees
use the search on the forum.
There is a workaround for I2 and I3 on the DD1 dimmer.
Posted: Thursday 11 August 2016 20:48
by leby
I have searched and seen your (perhaps not so) helpful help in other posts where you just say search the forum. The results I have seen have not helped me, perhaps because I did not understand the solution. Different users on this forum has different level of skills....
Should perhaps add that I have put parameter 100 and 101 to binary and excluded the node (less 2-3 seconds press only to keep the parameters) and then included it again. I have also associated group 5 and 8 to the controller.
Posted: Friday 12 August 2016 7:34
by Egregius
Posted: Friday 12 August 2016 12:03
by leby
Hi, thanks and yes. It does not help me (I think). First I run Windows version and the problem is not that is not a switch, I don't get any signal at all from I3 on any device. I will use it for triggering scene so a simple binary on that directly turn off is not the issue.
